Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Race Brakes Sydney
Race Brakes Sydney Street and race performance pad / rotor combinations as well as brake upgrades and Exedy clutch kits. Website Link
Old 21-10-2012, 05:35 PM   #1
lachyjohno
77 F100
lachyjohno's Avatar
Default Play in caliper guide pins
Hi,
I've got an 02' AU III Wagon with 120,000km on the clock, which has a brake shutter problem that you feel through the steering wheel, so I have opted to do new DBA rotors and Bendix Ultimate's all round 4 corners...
Anyway, checking everything else is in good working order while I have the chance, when checking that the calipers are sliding easily (which they are), I noticed there is a small amount of play in the guide pins on both fronts. (ie. you can wiggle the whole assembly up and down on the pins, and slightly side to side as well...)
Just wondering whether there should be no movement like that as such, and whether that movement would contribute to the shutter?
I don't want to install all the good stuff, to find out that the pins should have been replaced.
Do you guys know if you can replace just the pins, rather than purchasing a whole caliper assembly? I'll get you to quote me on whichever parts I might need...
Appreciate your assistance,
Cheers,
Lachy.
Lachyjohno
My 77' SWB F100 Project thread
lachyjohno is offline   Reply With Quote Multi-Quote with this Post
Old 22-10-2012, 11:05 AM   #2
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Default Re: Play in caliper guide pins
Originally Posted by lachyjohno
Hi,
Cheers,
Lachy.
Hi mate there will be some movement but it is very hard for me to say if anything is wrong with these calipers just by the cescription especially when we see these and other calipers do many more km's than those without isse. I suspect the shudder is from the rotors and pads but if you are unsure you may need to have them inspected or compere them with another set by a local mechanic. Sorry i couldn't help any further but i also doubt the slide pins will be available seperate.
MATTHEW PEARCE
RACE BRAKES SYDNEY = When you want it to stop
Street to track is what we expertise in
Phone 02 9609 1101
sales@racebrakessydney.com.au
www.racebrakessydney.com.au
