31-10-2012, 06:24 PM | #1 | ||
Hey all.
I recently replaced my front brakes with Bendix pads the other day, and they are starting to squeak a fair bit. I've purchased this "De-Squeak" stuff but it never works. Anything I can possibly do to stop the squeaking? |
31-10-2012, 07:34 PM | #2 | ||
Don't use the brakes? :p
31-10-2012, 07:40 PM | #3 | |||
Performance Inc.
I have really hard pads in my car when they start to squeak one really hard stop usually sorts them out for a while. Hard pads when used in gentle braking sort of glaze the disc one hard stop removes the glazing and the squeak.
In The Garage... FPV Super Pursuit Build no 0080/91 Lotus Exige S/C S240 Kart Hasse Chassis 100J Power Quote:
31-10-2012, 07:41 PM | #4 | ||
31-10-2012, 07:42 PM | #5 | |||
31-10-2012, 08:09 PM | #6 | |||
31-10-2012, 08:51 PM | #7 | ||
I have Bendix in my car and they have never squeaked. Some cars have thin anti rattle plates installed with the pads but owners do not reinstall them with new pads. =squeaking. Get the discs skimmed, that usually stops it.
31-10-2012, 08:53 PM | #8 | ||
BEAR
Might not be the pads, sometimes its the anti-rattle clips and self centre-ing pins. Never-seize or CopperKote them when re-assembling. Bush mechanics used to trace an outline of the pads onto a cereal box, and cut and paste it on the back of the pads. LMAO. Could be the discs need machining, they warp a little with heat, and as they rotate, they make the pad 'squeak' back and forth, in the calipers.
If you're still in control.....you're not going fast enough. |
31-10-2012, 08:55 PM | #9 | ||
If that's the little tin shim things. I installed the new ones.
I'll see if I can find a shop that will do that for me. |
31-10-2012, 09:10 PM | #10 | ||
Peter Car
Accelerate to 100 and then on the picks hard. Repeat a couple of times.
Sometimes works to get rid of possible glazing. |
31-10-2012, 09:12 PM | #11 | ||
Will try that tomorrow, thanks for the tips
31-10-2012, 09:51 PM | #12 | |||
31-10-2012, 10:44 PM | #13 | ||
MY2010 SV6 SIDI -Black-
did you bed the brakes in correctly?
generally they only squeal when not bedded in right. http://zeckhausen.com/bedding_in_brakes.htm |
31-10-2012, 10:54 PM | #14 | ||
How we treat brake squeal at my work;
Remove pads completely, and chamfer the edges of the friction pad itself on all pads. With a very rough grit emery paper, scuff the rotor in a cross hatching pattern all the way around, on both sides of the rotor. Then apply your de-squeak to the scuffed rotor. Works everytime. Cheers |
31-10-2012, 11:36 PM | #15 | ||
Which Bendix pads are they? I though the GCT ones were ok in a BA... The Ultra Premium Ceremic ones are way too hard for my liking, takes plenty of heat for them to come good and they do glaze up and squeal if you're not careful. Haven't tried the general performance ones.
MY CARS:
- FG XR6 Turbo, 6 Speed Manual, Silhouette . 12/78 XC Ford Fairmont Project Car. (351, 5spd) Build Thread: http://www.fordforums.com.au/showthread.php?t=11444473 1968 Ford F350 LWB Dually. 300 Six, 4 speed. Beavertail project. |
01-11-2012, 12:17 AM | #16 | ||
Thanks guys will try all the tips and see what I can do. Not sure which pads they are, will check the box tomorrow.
Thanks guys. |
01-11-2012, 02:54 PM | #17 | ||
I used premium bendix on the ED, bedded them in and they are fine.
01-11-2012, 02:58 PM | #18 | ||
Flairs - Truckers Delight
had squeaky brakes
tossed the old pads, fitted new QFM ones squeal gone
01-11-2012, 03:20 PM | #19 | |||
http://fordforums.com.au/forumdisplay.php?f=335
I love Holdens.... |
01-11-2012, 04:55 PM | #20 | ||
You need to bed them in properly.
Are you discs okay??
2022 RAM Laramie 5.7 2023.50 Ranger Wildtrak 3.0 V6 Premium Pack 2024 Everest Sport 3.0 V6 Touring Pack 2025 Mustang Darkhorse 6M Blue Ember + Appearance pack ETA April 25. |
01-11-2012, 07:13 PM | #21 | ||
Performance moderator
Its often the movement of pads on your calipers piston..
A stainless steel plate between the two often fixes.. A light coating of never cease, graphite grease helps.. Don't apply to rotors or pads though.. Often a slight run out of rotor ??
01-11-2012, 10:34 PM | #22 | ||
Went out the road today, went to 100km, jammed my brakes on went to 20km and done that 8 more times. Come to a complete stop the next and the cabin filled with smoke nearly, rotors were red.
The squeak is gone though :P just hope my pads are still ok, they feel it. |
01-11-2012, 10:55 PM | #23 | ||
Thats a stupid thing to do in my opinion, only going to do more harm than good. Such as warping the rotors from too much heat, causing brake shudder. Once the brakes have been over heating, often brake fade occurs.
02-11-2012, 10:09 AM | #24 | ||
They seem fine to me.....
02-11-2012, 06:14 PM | #25 | |||
Performance Inc.
8 hard stops just to be sure... usually one does the trick, just gets rid of the glazing on the disc, a combination of hard friction material and girlie braking causes this problem happens with hard pads all the time. Happy the technique worked for you.
Damn I was hoping you were going to pull them all apart and spend your saturday in the shed covered in brake dust and shyte.............
02-11-2012, 08:35 PM | #26 | |||
Ice |
02-11-2012, 09:00 PM | #27 | |||
05-11-2012, 07:10 PM | #28 | ||
The best way to deglaze pads is to remove them and rub them in a figure 8 pattern on a bit of rough concrete,got told this years ago by a brake fitter and have done it ever since(make sure the concrete isnt too rough so it tears the pads to bits,just rough enough to take the glaze off)
Make sure there are no tiny rocks stuck to the pads before refitting. |
05-11-2012, 07:30 PM | #29 | ||
I'll try that sooner or later. They are squeaking at very very low speeds, If I'm doing about 5km, then they will squeak, any faster and nothing so I'm happy with that for now.
06-11-2012, 11:15 PM | #30 | ||
http://www.fordforums.com.au/vbporta...articleid=1157
I used to use CRC Disc Brake Quiet: But am now using some Bendix stuff with the Brembo setup that I now have. Either one will do. If you are pulling brakes apart, it is also a suitable time to make sure that all the contact surfaces are clean. http://www.fordforums.com.au/showpos...74&postcount=9
Click here for my previous Photo Essays and Build Threads.
------------------------------- Good people. Bad people. Smart people. Dumb people. Car crashes. Vomit. Read about it all at Cabloid, the web site that has stories and photos about my life driving a taxi at night. www.cabloid.com.au |
