i am getting a rubbing noise on right rear when i put foot on brake it also stays there for a few seconds after moving again.
wayne |
5.6L x 2 pilot
![]() ![]() Join Date: Dec 2009
My guess Wayne would be your rear brake pads need replacing. You will also need to get your rear disks machined if possible, but more likely replaced. The rubbing you are hearing is most likely the metal frame of the brake pad rubbing on the disk. This genereally renders your disks as useless - generally throw aways because of the metal on metal damage.
Get it checked asap. Stu
2002 AU II LTD 5.6L 342ci T3 Short, AFR165 heads, Comp XE270HR-12 Cam, Brembo 4/4s(355/330), T3 5 spokes, LC-1 wideband, Whiteline HD swaybars, TCE 3K Hi Stall, PWR Auto Trans Cooler, Koni shocks, King Low Springs, Hurricane headers, 100 cpsi cats, Twin 2.5" exhaust. Quarter Mile: 13.73 @ 105.86mph Runner Up NA/DA to BF Fairlane/LTD Geelong AFD 2024 ![]() 2002 XR8 pursuit 250 Custom twin 2.5" exhaust w Herrod modifed extractors, Tuned with Moates QH
+1,
definately check it out asap. also with the noise hanging on for a second or so after you have used the brakes. it possibly has sticky caliper slides? or the disc pads might not be moving freely in the calipers too?
Money Talks, but all i ever hear is it saying Goodbye!! |
