Old 12-01-2013, 09:21 AM   #1
Velociraptor82
Eat my Brake Dust
Velociraptor82's Avatar
Question Lead Additive
Hey all, I drive a 82 Meteor which is still running on leaded petrol. However I'm finding it increasingly difficult to find lead additive in my area. Since I'm not the only one out there who owns a pre 86 car, I was just wondering what products people use and where they purchase them from?
Small Ford Sunday 2009 - Best Modified Car presented by the EuroFord Club
Small Ford Sunday 2009 - Best Focus (Non-XR5) presented by the RS Owners Club of Victoria
Sydney All Ford Day 2009 - Best in Club presented by The Combined Ford Clubs of NSW
Small Ford Sunday 2010 - Best Modified Car presented by the EuroFord Club
If I'm going to Hell, I'm going in a Ford
Velociraptor82 is offline   Reply With Quote Multi-Quote with this Post
Old 12-01-2013, 09:29 AM   #2
Jim Goose
Default Re: Lead Additive
technically speaking there is no such thing as "lead" additive... upper cyclinder lube or similar is/should be available at any servo or car parts place.
The other option is to keep driving until the engine needs a rebuild and then redo the head with hardened valve seats...
You've seen it, you've heard it and your still asking questions??
Don't write off the Goose until you see the box going into the hole....
Jim Goose is offline   Reply With Quote Multi-Quote with this Post
Old 12-01-2013, 10:16 AM   #3
BigAL_250
and that's how it is
BigAL_250's Avatar
And if for some reason you actually can't find it wherever you are (which would be good to know), then most if not all auto parts stores should carry large bottles of it, you'd just have to measure it each fill.
1983 Ford XE Fairmont 2004-2009
2003 Ford BA Fairmont 2009-2010
2002 Ford BA Fairmont Ghia 2010 - 2014
2012 Ford FG MkII G6E 2014 -
BigAL_250 is offline   Reply With Quote Multi-Quote with this Post
Old 12-01-2013, 10:19 AM   #4
Neale
Neale's Avatar
I use te Valvemaster in the corty, made by Castrol & its cheap & treats 300 litres per bottle. I did use the Caltex one that I found at the Caltex servo but it only treats 100 litres per bottle.
I buy the Valvemaster at Repco but I've never had a drama being able to get lead replacement at any parts shop or servo.
The lead replacement stuff is the cheap option as re doing the head may cost more than the car is worth.
Neale is offline   Reply With Quote Multi-Quote with this Post
Old 12-01-2013, 10:20 AM   #5
Yellow_Festiva
Where to next??
Yellow_Festiva's Avatar
I used a white bottle of stuff from supercheap, was pretty big, perhaps 1 litre. Morleys or something that starts with l ? Upper cylinder lube was its name.
There are kits I've seen that plumb it into the fuel line, don't know how good they are in terms of safety or correct dosage.
___________________________
Old 12-01-2013, 10:27 AM   #6
rushing on acid
rushing on acid's Avatar
those moreys kits from memory are called flash lube and were fitted to earlier lpg converted cars.
rushing on acid is offline   Reply With Quote Multi-Quote with this Post
Old 12-01-2013, 10:39 AM   #7
Yellow_Festiva
Where to next??
Moreys that's it ;). Ran that through a worked Sprite for years with no ill effects.
Old 12-01-2013, 11:11 AM   #8
Gavin Thomas
* 1973 ZF Fairlane 500 *
Gavin Thomas's Avatar
Your wasting your money if you pay to put anything other than "standard" unleaded in a POS Meteor....
As it has an alloy cylinder head, it will already have hardened valve seats from factory - proberly stelite valve seats or such. In any case there will be an insert of some type of hardened material - & in any alloy head, with most being of a suitable type for unleaded fuel use.
Enquire with a couple of engine machine shops / cylinder head shops for confirmation with your vehicle.
Even if not, then as others here have mentioned, do what the majortiy are doing & just run the fuel without additives, & then worry about options if or when the seat wear may cause valve recession.....
Don't cause any further polution from your "Ford" than the minimum needed whilst burning up the precious oil resorces of our planet.
Cheers.
Current
* 2023 Camry Hybrid
* 2004 Camry, still going good
Previous Classic Fords
* 1960 XK Deluxe Sedan
* 1962 XK Deluxe Sedan
Gavin Thomas is offline   Reply With Quote Multi-Quote with this Post
Old 12-01-2013, 11:38 AM   #9
XR Martin
XR Martin's Avatar
Partially agree with above, seeing as its an alloy head you can run fuel without the upper cylinder lubricant.
But id probably run 95 octane as leaded fuel had higher octane than regular unleaded which it may ping on.
2004 BA wagon RTV project.
Old 13-01-2013, 10:05 AM   #10
Velociraptor82
Eat my Brake Dust
Flash lube value saver Lead replacement is what I had been using, however in Pakenham (vic) I have been having troubles trying to find it in large quantities. All I could find were these single dose squirt bottles. Now it seems to be labelled as LPG/CNG Protection which I'm not entirely sure is the same stuff.
I don't often walk into Caltex as I'm always using BP, but I'll have a look. The valvemaster stuff I have also seen, but again I've only seen it in small bottles.
Thanks for the help guys.
Old 13-01-2013, 05:51 PM   #11
Phil B
Clevo power!
Phil B's Avatar
I get the Moreys stuff from my local Autopro, they always have a range of similar products. Had no problems in my Clevo. It's a good excuse to get an engine rebuild past the Mrs though: "If we get the engine rebuilt we wont need to keep buying this stuff!"
The beast: XB coupe, 302, manual all the way!
Fixing up thread
The purple monster, daily BA XR6 turbo.
Scale Lego Technic XB Coupe with working bits! Build thread
Phil B is offline   Reply With Quote Multi-Quote with this Post
Old 13-01-2013, 05:58 PM   #12
FGII-XR6
FGII-XR6's Avatar
your car should be ok without it jap cars were ready for unleaded long before Australian cars ( meteors were brought into Australia in CKD form and assembled here) check with an engine rebuilder and you'll find out if the valve seats are ok for unleaded ( hardened seats). if not install a flashlube kit, LPG installers swear by it . you just use ordinary petrol and top up the flashlube bottle (a bottle full lasts a few tanks )
[SIGPIC][/SIGPIC]
Rides:
Old 13-01-2013, 05:59 PM   #13
FGII-XR6
FGII-XR6's Avatar
go to a LPG installer they sell it in 5L bottles
[SIGPIC][/SIGPIC]
Rides:
Old 13-01-2013, 08:23 PM   #14
b2tf
not here much anymore
b2tf's Avatar
Any autobarn can order the Flashlube stuff in 5L quantities. Ive got about 5 bottles of it in that size on the shelf.
2024 F150 XLT
