04-05-2013, 05:14 PM | #1 | ||
Thailand Specials
Hey guys, I'm after some advice on ceramic coating, I've got a Holset HE351VE turbo coming in the mail, and I'd like to get it ceramic coated, some quick google-fu says the black type is better than the shiny "look at me" one.
What parts of the turbo can you get coated? Just the exhaust housing? Or can I just send them the whole thing and it goes in for a dunk and inside/outside/spinning parts can be coated too? I'm interested because my coolant overflow bottle is actually right above the turbo on my GMC Sierra, and I'm having the feeling if I start putting out a lot of heat, she's going to melt? Has anyone had any experience with this stuff? Thanks much. |
04-05-2013, 05:54 PM | #2 | ||
Performance moderator
Yep good stuff .. I have it on hot and cold sides.. critical areas I would still fabricate a shield though..
04-05-2013, 06:22 PM | #3 | ||
How are you going to control Variable Vane ?? If it is ?
04-05-2013, 06:23 PM | #4 | ||
Where to next??
Is the new turbo any bigger Damo? Just wondering if it is of any benefit seeing as the setup would have probably been driven much harder on duty than you ever would?
Having said that, if it is just for piece of mind a combo of the coating and shield wouldn't go astray.
___________________________ I've been around the world a couple of times or maybe more....... Last edited by Yellow_Festiva; 04-05-2013 at 06:35 PM. |
04-05-2013, 06:43 PM | #5 | ||
Oh ok on std turbo diesel.. Yes just ceramic coat turbine housing and dump pipe..
Or some fibreglass tape on dump pipe for the first 150mm or so..
04-05-2013, 10:24 PM | #6 | |||
Thailand Specials
The boys over at Diesel Place forums have managed to control it crudely using a spring, its functional but obviously not as good as a car with the function mapped into its ECU.
04-05-2013, 11:23 PM | #7 | ||
Call me dirt... Joe Dirt
I prefer the black too.
2007 BFII FPV Cobra Ute|Boss 302|6M|#23/100 Mods so far: Billet Products Shifter|X-Force Exhaust|Herrod Oil Breathers|Whiteline Sway Bar|Tein SuperStreets|Kings FOR-303SL Rear Springs|Melling Oil Pump|Mace Manifold Spacers|Powerbond Underdrives|Pacemaker Headers|Ballistic Cats|XFT Custom Tune @ 308.3rwkw|DBA T3 Rotors|Ferodo Pads|Goodridge Braided Lines Mods to come: 4.11 Diff Gears|Chromoly Tailshaft I use & recommend: Castrol|Motorcraft|Mainlube|Penrite Check Out My Build Thread |
04-05-2013, 11:41 PM | #8 | ||
my brother gets his extractors coated inside and out, i don`t know if one color is better than the the other, but he usually uses the matt black or grey.
this bloke(andrew) does a lot of hot rod stuff and is very good to talk to if you want get info. http://www.blastfactoryabrasiveblasting.com.au/ |
05-05-2013, 01:13 AM | #9 | ||
Sorry, I have to ask; why don't you want to hear your turbo?
Crazy Dazz
Kicking Hippies in the Balls since 1966 |
05-05-2013, 07:05 AM | #10 | ||
Falcon RTV - FG G6ET
Why drive around with that noise comming out of it - you know you have it, what do you have to prove.......
BAII RTV - with Raptor V S/C. RTV Power FG G6ET 50th Anniversary in Sensation. While the basic Ford Six was code named Barra, the Turbo version clearly deserved its very own moniker – again enter Gordon Barfield.
We asked him if the engine had actually been called “Seagull” and how that came about. “Actually it was just call “Gull”, because I named it that. Because we knew it was going to poo on everything”. |
05-05-2013, 09:52 AM | #11 | ||
Thailand Specials
Because it will be around the same as this, which is freakin' loud.
http://youtu.be/K49Ge7PZuog?t=41s You can already hear the factory turbo spooling up loudly inside the cab, even with the windows closed and all the crap in the back rattling around. The outlet on the exhaust of this new turbo, is 4", so that pretty much means I'm running 4" exhaust from turbo to the tail pipe, so even with mufflers and a cat in there, its probably going to still be on the loud side. |
05-05-2013, 12:35 PM | #12 | |||
They also have a web site They don't only do ceramic but also specialised engine component coatings I have used them and very happy with their service and quality |
05-05-2013, 02:54 PM | #13 | ||
yeah have nothing but good things to say about this bloke, we welded up an item and sent it to get a coating to andrew, after blasting it he found a bit of dodgey weld, he re welded it up and did the coating no fuss no problems, top bloke.
05-05-2013, 07:55 PM | #14 | ||
on the way to the RSL
HPC down in Leongatha are a great place, had all my housings and dumps done there. For memory my GT42 exh housing was $80, the finish is still perfect on it, id still run a blanket/beanie on it if you want to protect surrounding areas.
ED GLi - DOHC - GT42R - 2 Speed - 275 Radials- Moser 9" 8.9x@160mph+ |
