Old 07-06-2013, 11:41 AM   #1
allanv6gt
Tippy-tronic Free Zone
Default Ford Type 5 Gearbox - need some bits
Hi folks,
Just acquired a Type 5 4spd to replace the external linkage one on my Capri V6.
But....Need a few bits to make it all complete
Anyone know where I can find these?
Part Number 72GG-7227-AA
Description Compression spring on manual gearshift lever, between nylon ball and upper cone + lock cap
Part Number 72GG-155520-CA
Description Reversing light switch
Part Number ?????
Description Boot covering shifter shaft entry into gearbox extension. Not sure if same as item below, I don't have the parts diagram, only a parts listing.
Part Number 72GG-7277-NA
Description Boot - gear change lever (? possible part number for the gearshift into the box, or even the floor hole cover)
Thanks in advance.........
Old 07-06-2013, 12:20 PM   #2
cosworthfreak
cosworthfreak's Avatar
Default Re: Ford Type 5 Gearbox - need some bits
Hi Allan,
The reverse light switch can be sourced from ebay or Burtons: http://www.burtonpower.com/tuning-gu...e-gbt9545.html
You can buy new and used gearshift assemblies (depending on the thread size needed) from Motomobil in Germany, who would also have the reverse switch: http://www.motomobil.com/produkte,32...egory_id=12&q=
Not sure if anyone in Oz can source these?
Jamie
cosworthfreak is offline   Reply With Quote Multi-Quote with this Post
Old 07-06-2013, 12:26 PM   #3
cosworthfreak
You may need to be creative with the floor hole boot, as the rubber boot for the type 5 was round like the 4cyl ones. Maybe fit a boot from the external linkage box with the metal surround to clamp it down?
Old 07-06-2013, 07:53 PM   #4
allanv6gt
Cosworthfreak - thanks for the reply.
I'm aware of Motomobil (EUR100+ for a gearstick) and Burtons for the reverse switch.
And the gearstick boot-over-cone I need looks awfully like a Type 9 style.
Was hoping to find things a bit more local .....Ha ha ha, yeah right.....
Old 20-07-2013, 02:29 AM   #5
whooligan
whooligan's Avatar
Try an Escort boot...,may be a little small.
I recently picked up a type 5 from a new club member who recently arrived with a container load of parts from the UK....As you can image, he's a popular fellow at the meetings. PM me and I'll forward you his mobile number. Pretty sure he can help.
whooligan is offline   Reply With Quote Multi-Quote with this Post
Old 21-07-2013, 09:31 PM   #6
allanv6gt
Well, after some digging around the web and my boxes of junk.....
1. I found the steering wheel hub spring will do for the gearstick compression spring.
One problem solved.
2. The reversing light switch I bought from Burtions and was assured was correct....ain't.
A 3/4" x 2.5tpi is not equal to a 14mm x1.5tpi (nil response to mismatch issue I raised with Burtons).
Some other web sites have them listed - Motomobil out of stock (no supplier), another queried with no response, and another site I ordered successfully was cancelled with 'the website is built wrong, no supplier'. Marvellous.
Or..I'll try soldering some pins onto the back of my ground-away old switch.
Or..I'll make a threaded sleeve to pad out the Burtons-supplied Type 9 switch to fit the Type 5 box.
3. The boot into the geatrstick extension can be mostly covered by a 4 cyl gearstick boot. Might do at a pinch.....
4. The floor boot I can use a generic or a 4cyl as suggested, so no problem there.
Some progress, other issues need more thought.
p.s. Whooligan - PM sent
