03-07-2013, 08:59 PM | #1 | ||
Hi was wondering if anyone new if you can put a turbo throttle body on a na if so can I put the hole intake manifold. Are stock injectors same?
03-07-2013, 09:25 PM | #2 | ||
Im pretty sure the n/a 6 and turbo 6 throttle bodies are the same
FG XR6T Ute
300rwkw |
03-07-2013, 09:53 PM | #3 | ||
Ok cheers I also have just bought a turbo kit for my 03 xr6 na and have bought some turbo pistons rods and valves turbo head gasket would that be enough to lower compression do u no.
03-07-2013, 09:54 PM | #4 | ||
Won't to run about 10lb daily.
04-07-2013, 06:08 PM | #5 | ||
I think you may be better off posting in the B-Series room or the BA-BF section.
More guys in there that could answer your questions. Give as much info as possible.
1976 XB Falcon 500 Wagon - BUILD THREAD Sherwood Green | 3spd/250CI | Running Whitewalls on a 2.5" Drop |
