Old 14-07-2013, 02:22 PM   #1
Hell Cat
Default sealing up a shed/weather proofing tips? shed upgrades?
Hi.
Just wondering if anyone here has had experience sealing up their sheds from mice/creepy crawlys/weather?
My shed is a 6x9 stratco, the outer sheet metal over hangs against the slab, fortunately I have never had any water leak into the shed (Only when pressure washing near the doors.
I would like to try to seal the gap between the slab and sheet to prevent dirt/mice etc coming in through the gap, I unwrapped my engine that was has been tucked in the corner to discover mice had made a nest.
Im also hoping to try to seal up the top where the roof meets the walls.
Im (reluctantly) letting the mrs have one bay of the shed to set up her sewing equipment because she's starting her sewing business back up again.
The fabrics are quite expensive so I'd like to prevent any un-necessary damage....
After that I will cover the floor with lino or the industiral resin/flake coating, I have been
thinking about insulating the shed also and putting up smooth walls inside to make it a bit more comfortable in summer and also look better on the inside. Ply/chipboard/gyrprock? Not sure how it would hold up as it expands/contracts with the weather.
Overhead wall storage? Have you done it?
Hell Cat is offline   Reply With Quote Multi-Quote with this Post
Old 14-07-2013, 02:26 PM   #2
Hell Cat
Default Re: sealing up a shed/weather proofing tips? shed upgrades?
Outside
Inside (note the small gap)
Top (more gaps)
Old 14-07-2013, 02:37 PM   #3
05_ENFORCER
05_ENFORCER's Avatar
Proper way, Vermaseal or Retroseal rural, cheats way, Fillafoam for the floor to walls.
Can't remember the name of the high density foam stuff that packs the gap wall to roof sheets sorry
PA door can use std weather strip or brush strip.
Only real way of reducing/eliminating the ingress of dust/dirt etc is to positive ventilate using filtered air or an evap aircond unit.
It doesn't need to be mounted on the roof either.
2015 FGX XR8 5.0 S/C 645 RWKW
05_ENFORCER is offline   Reply With Quote Multi-Quote with this Post
Old 14-07-2013, 02:58 PM   #4
DJR MAN
DJR Fan
I was going to use expanding foam in the gaps between slab and walls in the next few weeks - hopefully that will do.
DJR MAN is offline   Reply With Quote Multi-Quote with this Post
Old 14-07-2013, 02:59 PM   #5
poppa smurf
poppa smurf's Avatar
the name of the impregnated foam is commonly called B.I.P. (Bituman impregnated polyurethane)
go to any shed or carport sales and ask for B.I.P. it comes in rolls of 10 mtr's (from memory)
I agree with all of the above.
G'day....I'm Dave, ...everyone calls me Poppa,..05.. B.A. Fairmont mark II...
may your day's be filled with smiles, your life be filled with love, may your children know nothing but happiness and joy, cherish the memory of those who strove before us for they cleared the way, spare a thought for those who serve we owe so much to so many, life and the freedom to enjoy it is a special gift that can be taken away far too soon!
poppa smurf is offline   Reply With Quote Multi-Quote with this Post
Old 14-07-2013, 03:12 PM   #6
DJR MAN
DJR Fan
I just had a look at the Titan website and I might get this instead now. I'm sure Stratco would do something similar.
http://www.titanlite.com.au/parts/ve...-for-qdek.html
Old 14-07-2013, 03:20 PM   #7
poppa smurf
yep! looks like it would do the job, just check the thickness.
if it is a bit loose it will fall out (happened to me) it needs to "expand" into the gap in order to be secure, just ask about its lifespan as well, some only last about 10 years.
Old 14-07-2013, 03:30 PM   #8
05_ENFORCER
That's the stuff I was trying to describe
Old 14-07-2013, 04:52 PM   #9
290GTP
290GTP's Avatar
Originally Posted by Hell Cat View Post
I have been
I lined the walls of my shed with 16mm White particle board. Just pack it up app. 20mm off the slab & screw straight to the steel framework. It looks good as is or you can paint it if you want. It also makes it easy to hang hooks, shelving etc to the walls.
Just go to any good sized joinery & ask them if they have any cover sheets that they want to get rid of. Most of them are only too happy to offload them.
Mercury Silver 03 BA GT-P Tremec TR3650 Number 534
Herrod 4 into ones, Manta Exhaust, CAI, K&N Filter, Mellings oil pump, 19" FPV alloys, Bilsteins, Kings, tuned by Autotech, 272rwkw
RIP Fish 15/1/73 - 9/2/19
290GTP is offline   Reply With Quote Multi-Quote with this Post
Old 15-07-2013, 12:21 AM   #10
Hell Cat
Thanks for the info.
I will hopefully buy some of the retroseal tomorrow. (Bit expensive)
