Old 11-08-2013, 08:08 PM   #1
camute
Default front wheel bearing hub torque setting
Hi there guys,
just put new bearing hubs on my AU1 wagon,
Does anyone know how tight i should tighten the big nut?
Many thanks.
camute is offline   Reply With Quote Multi-Quote with this Post
Old 11-08-2013, 08:42 PM   #2
Gaz
Got Ghia?
Gaz's Avatar
Default Re: front wheel bearing hub torque setting
Believe it is the same as au2... somewhere near 300nm will do it.
(manual gives the 305nm figure, also references a range of 260-350nm)
2007 BF MKII Ghia V8 - BA GT Exhaust| F6 Intake | Superlows | 19" GT-P's | 30mm Swaybar | - Sold
2002 AU2 XR8 Ute - Manual | Leather | Injected LPG | Pacemakers
Gaz is offline   Reply With Quote Multi-Quote with this Post
Old 11-08-2013, 09:15 PM   #3
fordman302
fordman302's Avatar
Ft.....
fordman302 is offline   Reply With Quote Multi-Quote with this Post
Old 11-08-2013, 09:20 PM   #4
saber
Yep, around 305NM sounds right.
If you don't have a torque wrench that will measure up to the above figure, you can count the number of threads the nut on your other wheels is on from the end of the shaft. Then apply that number to the wheel you want to tighten. It should be close to factory spec.
saber is offline   Reply With Quote Multi-Quote with this Post
