18-08-2013, 01:31 PM | #1 | ||
my rear sl king springs have sagged a bit with the lgp tank.
rather than get new sl's and have them sag again or goto low's and have it sit too high i was thinking that maybe i could get some coil spacers about 15mm thick to bring the height back to where it should be. is this as simple as it sounds or am i missing something here? |
18-08-2013, 02:13 PM | #2 | ||
i don't see why it would not work, but if it were me , i think i fork out for some more suitable springs, perhaps a bit heavier to make up for the added weight of the lpg tank.
18-08-2013, 03:03 PM | #3 | ||
a bit heavier would be nice, but then what springs would i go for? and it would be a bit of a gamble getting the height right.
18-08-2013, 05:23 PM | #4 | ||
sorry i wouldn't have a clue mate, a suspension place should be able to give you a heads up.
18-08-2013, 05:44 PM | #5 | ||
Auto Nerd
If it helps you, I have a dual fuel set up on an AU III. Have king lows on all round.
From hub to guard. Front - 355mm Rear - 345mm. |
18-08-2013, 07:44 PM | #6 | ||
yeah, mine are 335mm front and 320mm rear. i just put a jack under the towbar and lifted it upto 345mm, it still looked pretty good so it might be a good compromise.
18-08-2013, 09:28 PM | #7 | ||
Peter Car
I used Whiteline 10mm coil spacers in the rear of my Fairlane.
