Hi all Ive got a 1986 Sierra XR4ti 2.3 four cylinder turbo
and it pours a lot of smoke out of the timing belt/chain cover it looks like steam /oil vapour and settles back on the motor as oil I borrowed a trade plate and took it out for a run and smoke came through the air con vents the other thing is with the gear stick I have trouble finding gears they are all over the place from 1st to second sometimes you get 4th if you are not careful the same with 1st and reverse no lock out it says press for reverse but you dont have to other than that the car runs very well with plenty of stick also the clutch has to be pushed hard on the the floor to change gears is there a seal of some sort behind the timing cover and can it be got to easily or am I in for dramas Ive never seen one of these cars before so Im hoping someone on here knows thanks John |
Looking for clues...
Yes John, I bought a whole engine gasket kit for mine, which came with the seals for the shafts at the front of the motor, as well as every gasket in the engine. There are seals at the camshaft, distributor shaft and crankshaft at the front of the motor.
This is where I got mine from: http://merkurmidwest.com/catalog/i111.html From experience, you'd be better off pulling out the engine to do all the seals, as with the age of the car, the rubber seals dry out and shrink. Your valve seals will probably need doing as well. Swanny
2016 Ford Falcon FG/X XR6 Turbo you beaut ute 1985 XR4Ti Sierra - Build Thread 1971 Fairlane 500 and... a collection of Jeep Towpigs and... two collections of rust and some new plastic bits roughly shaped like an F-Truck and.... some spare metal bits with holes in them Last edited by Captain Stubing; 02-10-2013 at 12:10 AM. |
Hi I'm based on the Gold Coast and do a lot of work on ford sierra Xr4ti/xr4i and Rs Cosworths if you need a hand with sorting yours or are interested in selling please call mine self Aarron on 0431649697
I'm positive he sold it on Ebay, Aaron.
2016 Ford Falcon FG/X XR6 Turbo you beaut ute 1985 XR4Ti Sierra - Build Thread 1971 Fairlane 500 and... a collection of Jeep Towpigs and... two collections of rust and some new plastic bits roughly shaped like an F-Truck and.... some spare metal bits with holes in them |
