Old 13-10-2013, 08:26 PM   #1
paul84
Default ED gutless
Hi guys
Need a little help diag an issue with an ED falcon. It's been sitting in the garage for the last 3 weeks and something's gone astray. Was driving perfectly fine before hand and no mech work done to it whilst it was in the garage.
What the issue is, is it has no get up and go. Barely pulls up a hill and cough and splatters at idle. At first I thought it was low fuel as it had less then 1/4 tank. But fresh full tank of fuel has made no difference.
Checked ignition timing and spark, all good. Air filter isn't blocked and there is no apparent vacuum leaks. Spark plugs were black and sooted up. So I'm assuming its running rich. Cleaned them up and first drive they were back to sooty black.
What I have noticed is when it first starts in runs fine for first 10-15 seconds, then you hear the revs drop slightly and then it starts to cough and splatter. Short revs and its almost stalling.
I'm assuming something might be wrong with the MAP sensor or maybe blocked fuel filter, however it's running rich and I cannot see any possible association with a blocked fuel filter and running rich.
Any help, much appreciated!
paul84 is offline   Reply With Quote Multi-Quote with this Post
Old 14-10-2013, 08:52 AM   #2
paul84
Default Re: ED gutless
Apologies, can I get this moved. Thanks
Old 14-10-2013, 09:30 AM   #3
Sorted
OzEcruisers PRESIDENT
Sorted's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: For all the contributions you make to the AFF community.
Fuel Pump could be on it's way out
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan
PROEF 13.46 @ 105.78mph
Tuned by DYNOMOTIVE
200BUX - AFF Drag Nats 2019 EF Wagon
Common knowledge that the more weight you take out of the car the less power you need to run the time.
Sorted is offline   Reply With Quote Multi-Quote with this Post
Old 25-10-2013, 07:47 AM   #4
LTDHO
The one and only
LTDHO's Avatar
How many k's has it done?
Could be injectors gummed up, faulty oxy or faulty coil.
Tuned by CVE Performance
Old 27-10-2013, 02:48 PM   #5
paul84
Just an update. Replaced oxy sensor, new plugs, leads, rotor button and distro cap. Checked ignition timing. Haven't changed the coil yet. Car has done just over 320,000k
Engine deffinetly running rich. Starts and runs good for first 30-40 seconds, then rpm drops to a slow idle and produces sooty black exhaust.
Absolutely no pull up hill, car struggles and won't go past 30kmh in first gear, foot flat. Can hear a cracking and popping noise down the exhaust at idle. I'm assuming its unburnt fuel combusting in the catalyic converter.
Edit: Forgot to mention changed MAP sensor also
Old 28-10-2013, 10:00 PM   #6
paul84
Just update. Ended up being ignition coil. Thanks for everyone's suggestions
Old 01-11-2013, 01:40 PM   #7
LTDHO
The one and only
LTDHO's Avatar
Ha ha, thought so!
