![]() Join Date: Jan 2013
Hi Guys, I have heard from a couple of people in Vic that they had experienced registration trouble when they tried to change their 6cyl car to an 8, i am talking about cars that came factory optioned with V8s ok, so it is a straight swap of all the usual V8 gear to make effectively a std V8 car. The problem has been the body number comes up on the system as 6cyl and registration is denied unless the car is made 6cyl again? Anyone else heard of this?
Cheers, Steve. |
64 Deluxe 4 door
![]() Join Date: Jun 2007
Wouldnt you just need some sort of mod plate etc (or whatever its called in Vic)
If Vic runs under the new modification rules, then say a 351 into an XY should be fine, as it was a factory option. If factory V8 needed certain brakes, then you would need them to be fitted. I think that in NSW such a mod would come under owner certified. There are other issues such as a late model EFI engine into an earlier model, you need all the modern emissions junk. Anything on vicroads website??
XM Deluxe FG XR50 BA Pursuit Ute |
#3 | |||
taken from vic roads web site
Thanks for this is it current? All i know is that both guys were given the excuse of the body number comes up in the system as a 6cyl car if you want a V8 you need a V8 bodied car? I have a 6cyl to V8 conversion FD LTD coming up for Roadworthy/Registration soon and i don't want these kind of hassles myself, It is bugging me enough to go to the local VicRoads branch and find out.
Cheers, Steve. |
Needs to be checked by engineer & signed off stating it has met the V8 requirements.
Is this a new rule? and you know this for sure? And who is supposed to pay the $500+ to the engineer? Vic Roads needs to be *****d and burnt and i don't care what order it happens in! nobody is going to want to touch a car in Victoria soon, it will be too much of a pain.
I totalled my XR6
I think it's safe to assume the vehicle's owner pays for the engineer's certificate in this case.
I had to get an engineers certificate when my 05 F350 ambo was converted to a tray body. Cost me $350 [18 months ago] with 2 inspections, money well spent in my opinion, no rego hassles if I sell, you will not get a roadworthy with a different body fitted and no insurance knock back on a claim. Even have it noted on my policy.
Pete Last edited by monzie; 15-12-2013 at 11:00 AM. |
#9 | |||
Thailand Specials
What was involved in the process, was it just removing the rear body and getting a tray made up, then having it seen by an engineer? I've got a question on the engine conversion front, I've got a Cummins 6BT here, its a 5.9L I6 turbo diesel engine, ambo currently has a 6.5L TD V8 under the hood, would I have to go for emissions testing even though I'm going to a smaller, newer engine? My engine is stamped Jan 2004, the one in the ambo is 2001. |
#10 | |||
just to add to my post above
http://www.vicroads.vic.gov.au/Home/...ifications.htm the car only needs an engineers cert if the engine was not offered as part of the original release for that model ie If i wanted to put a v8 in my el as long as ford released the el with a v8 i can fit it as long as the capacity was available in that model so i can fit a 5ltr into it with only a visit to vic roads with the change of engine paper work and it will be done
Thailand Specials
I might need to talk to an engineer, wasn't offered as an option, its also about 250kg heavier than the V8.
http://www.vassengineer.com/About-Us.html I emailed these guys, $50 for an email, I hope he tells me what I want to hear lol. Last edited by Franco Cozzo; 15-12-2013 at 01:25 PM. |
#12 | |||
#13 | |||
The main thing is you are changing from, in my case, 4 seats back to 2 seater. My first inspection was a general look to see what, if any thing was needed, second was to check that it had been done. He checked the back wall of the cab [original], that the rear window was approved, the number of seats, tray size and mountings, mud guards and mud flaps, tail lights etc etc. He took hundreds of photo's of every thing including close-ups of ADR approval numbers on tail light lens, reflectors and rear window, compliance plate and engine number . The only thing extra I had to do was fit amber side reflectors to the side of the tray and a couple of red ones to the rear At the second look he watched as I fitted the blue approval plate in the engine bay, [he supplied the drill and pop rivets] and then took pics of it fitted, handed me my VASS certificate, all done. Fitting a Cummins would need approval of the engine mounts I would think. Pete |
#14 | ||
Thailand Specials
Thats why I want to leave it as an ambo, everyones like convert it to a tray back but there is a lot involved. Can you legally use those 2 seats in the back? My compliance plate says 4 seater on the ambo body, and the seats have seat belts.
But the rego only says 2 seater, but it is registered as an ambulance. |
#15 | ||
I would think the plate on the body would cover the seats in the ambo and if it was OK for paramedics to travel in them why not your family/friends.
I obtained a copy of the original [when it was built as a ambo] VASS certificate from Vicroads. Because mine has a chassic extension having the first certificate made it a lot easier to do the second one for the tray. Your Chev being an older model might not still be on record. Give VR a call, never know your luck in a big city. Pete |
#16 | ||
They told me they don't have accurate records for vehicles earlier than 1980 or 1986 i cant remember exactly but the point is the options they gave me were good and bad, and it would depend on the official on the day as to what you got
#17 | ||
The VSB modification codes that are relevent for my 05 model F350,
2005 First VASS certificate, ambulance body, 4 seats, 1 stretcher. H1-chassic extension C1-longer tailshaft F1-rear air suspension J1-body mounts M1-fuel tank K1,K2-seats and seat belts 2012 Second, as above, tray body, 2 seats LK1- tray Don't know if this is any help to you with the numbers on your body compliance plate Pete Last edited by monzie; 20-12-2013 at 10:44 AM. |
