Old 22-01-2014, 12:07 PM   #1
Craigos
Default Yo There
Hi to all, another newbie calling through to say hello.
Got an 03 BA Sedan, usual issues, but an ok car I suppose....
If the damn handbrake wasn't such a pain I would rate it higher....
Craigos is offline   Reply With Quote Multi-Quote with this Post
Old 22-01-2014, 10:21 PM   #2
jaydee
jaydee's Avatar
Default Re: Yo There
Hey mate and welcome, yep the BA, what can I say. I'm in the same boat, hand brake, front discs warping, headlights blowing, roof lining falling in, door lock actuators, drivers door window regulator (twice), radiator by pass for tranny, heater (dash out job), and the list goes on.
Good motor though, very reliable.
jaydee351
4DV8
jaydee is offline   Reply With Quote Multi-Quote with this Post
Old 22-01-2014, 11:09 PM   #3
Craigos
Yeah, if they made the car out of the same stuff the engine is made out of, then, all would be good......
Biggest issue is the stalling issue when just cruising along.....
I have found a thread on here about the reset procedure for both the ECU and the TPS. I did that two nights ago, and, the car hasn't gone so well. Really pulls like a train, at the moment.
If it does the stall again, i will replace the TPS. It currently has the original OEM version with the depression in the housing.
Does anyone else have that annoying "ticking" sound in the interior fan ?
It improved when i cleaned the intake filter screen, but, i dunno, it must be a male thing, cause the wife and daughter cant hear it, but i and any other guys in the car can....
Old 22-01-2014, 11:59 PM   #4
csv8
csv8's Avatar
Could be a leaf in the fan..will go away as the leaf dries and fan chops it up..seriously!!
CSGhia
csv8 is offline   Reply With Quote Multi-Quote with this Post
Old 23-01-2014, 12:03 AM   #5
pottery beige
i've had none of those problems
you got a dud
Old 23-01-2014, 09:01 AM   #6
Craigos
I suspected the leaf thing, but I think it more related to the motor, or the bearings.... Have blown the whole thing out with compressed air, spun the fan back and forward by hand....but the only time you hear the tick is when it is operating.
Just have to put up with it....
Old 23-01-2014, 09:24 AM   #7
msman
take the fan out and lube the lower bush, normally makes a squiking noise though.
3 phillips head screws, get your head right under the glove box and you will see them.
whole fan assembly comes out.
then just pull it apart on the work bench and clean all parts, lube the lower motor bush some good oil will do it.
probably about an hours job.
if you do a search there is a write up here with pics.
msman is offline   Reply With Quote Multi-Quote with this Post
Old 23-01-2014, 09:42 AM   #8
Craigos
Cheers for that.... I looked at the fan box and thought screw that.... But if you reckon it's an easy out....then I will have a go....will look for the thread pics too.
Thanks again....
Old 23-01-2014, 08:36 PM   #9
MercurySilver
Isn't it obvious?
MercurySilver's Avatar
Do what I did.....traded it in and bought a turbo
08 Strike G6E T.
10 Ergo G6E
Sept 75 XB Falcon in mushroom beige, 3 on the tree 200cid for sale, offers in the teens
MercurySilver is offline   Reply With Quote Multi-Quote with this Post
