Old 05-03-2014, 10:43 AM   #1
GT2
Default Modeo Heat Exchanger Fail
Had the dreaded heat exchanger fail last Friday however it isn't a Falcon.
It failed in a 2011 Modeo TDI. In the diesel Modeo, the heat exchanger is located between the block and the radiator.
The car has 38K and was 4 days out of warranty.
To there credit, Ford customer service have taken on the case.
GT2 is offline   Reply With Quote Multi-Quote with this Post
Old 05-03-2014, 01:59 PM   #2
bangm001
Mopar! But Own F6's..
Default Re: Modeo Heat Exchanger Fail
Had a trans cooler let go on my wifes Astra twin top just out of warranty (few months out) too, they didnt cover it.. Same rubbish hey.
F6 TYPHOON
FPV 335 GT
bangm001 is offline   Reply With Quote Multi-Quote with this Post
Old 05-03-2014, 03:02 PM   #3
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
Do you mean Mondeo? or Rodeo?
Old 05-03-2014, 04:14 PM   #4
GT2
Default Re: Mondeo Heat Exchanger Fail
Mondeo,
Old 05-03-2014, 04:22 PM   #5
Road_Warrior
Pity the fool
Road_Warrior's Avatar
Interesting.
I wonder if Ford did a bulk buy on the same rubbish heat exchangers for a whole bunch of different models?
Fords I own or have owned:
1970 XW Falcon GT replica | 1970 XW Falcon | 1971 XY Fairmont | 1973 ZG Fairlane | 1986 XF Falcon panel van | 1987 XFII Falcon S-Pack | 1988 XF Falcon GLS ute | 1993 EBII Fairmont V8 | 1996 XG Falcon ute | 2000 AU Falcon wagon | 2004 BA Falcon XT | 2012 SZ Territory Titanium AWD
Proud to buy Australian and support Ford Australia through thick and thin
Road_Warrior is offline   Reply With Quote Multi-Quote with this Post
Old 05-03-2014, 04:29 PM   #6
johnydep
johnydep's Avatar
Originally Posted by Road_Warrior View Post
Interesting.
Why have Ford had this problem since the EF model? The AU went through several radiator cooler redesigns & still couldn't get rid of the problem. Ford then went to an external heat exchanger, telling all that the problem was fix. Nope, still happening.
I reckon it's the coolant. Probably becomes acidic as it ages.
The true danger only occurs when you take a potentially dangerous piece of machinery
and place it in the hands of the most unpredictable species on the planet.
Human behaviour, as history has catalogued, cannot account for what any persons actions may be,
especially concerning their love of the motor vehicle.
http://www.fireservicecollege.ac.uk
johnydep is offline   Reply With Quote Multi-Quote with this Post
Old 05-03-2014, 04:31 PM   #7
Road_Warrior
Pity the fool
That, and I'm pretty sure these coolers/heat exchangers have glue involved in their construction as opposed to soldering/welding.
Old 05-03-2014, 04:56 PM   #8
GT2
[QUOTE=Road_Warrior;5038277]Interesting.
I wonder if Ford did a bulk buy on the same rubbish heat exchangers for a whole bunch of different models?[/
The Mondeo cooler looks nothing like the Falcon one.
Old 05-03-2014, 04:58 PM   #9
GT2
Good point. I wonder if using that waterless coolant would overcome the problem?
Old 05-03-2014, 09:15 PM   #10
GREGL
Tell me if I'm wrong here but why would it be a coolant issue , when hundreds of thousands of cars use basically the same formula . Furthermore how does a car that has done 38k and assuming it has been serviced as per log book have a chance of coolant ageing ?
Wake up and stop putting up with crap its that simple .
GREGL is offline   Reply With Quote Multi-Quote with this Post
Old 05-03-2014, 09:27 PM   #11
GREGL
Why when you buy a new or near new car should you even have to consider overcoming a problem ? The reality is you shouldn't have to unless the standard of world class car has dropped . It is no wonder ford have problems and until they get their act together and FIX these dramas there life as an importer won't last long either .
Old 06-03-2014, 01:06 AM   #12
kempy311
BEN
kempy311's Avatar
But many heater exchanges are not rotting out they are cracking.
My Thread. The new whip: 2014 FGX XR8 Auto in victory gold. Mods : BMC air filter, 1500cc injectors, Walbro 485, 58mm kpm snout, kpm intercooler, 35% front and 20% rear tint, pedders supercar coilovers, whiteline sway bars, Phillips HIDs, lenso d1r wheels.
331rwkw.
12.7 sec stock as a rock with a passenger.
Now with 620rwhp ready to run the 10
built zf, built tailshaft, corn juice all to come.
The old rig: 2008 FG XR8 Auto in dash green with a tonne of mods to make 311rwkw.
kempy311 is offline   Reply With Quote Multi-Quote with this Post
Old 06-03-2014, 07:13 AM   #13
Trump
bitch lasagne
Trump's Avatar
Glue + high coolant temps by design + coolant turning to acid = death for the heat exchanger/cooler.
Scaled Business Solutions
For Your Small Business IT Needs
Trump is offline   Reply With Quote Multi-Quote with this Post
Old 06-03-2014, 09:19 AM   #14
simon varley
Technical Contributor: For members who share their technical expertise. - Issue reason: Bringing sanity to the Everest threads.
do you know how it failed? was there an external coolant leak, or was it internal and mixed with the oil?
simon varley is offline   Reply With Quote Multi-Quote with this Post
Old 06-03-2014, 11:02 AM   #15
johnydep
johnydep's Avatar
Coolant cause is only an educated 'guess'.
If the problem is a heat exchanger fault - then why has it only occurred on Ford items in such high numbers, and with different parts manufacturers?
That's what I've been asking myself for the past 15 years. We've changed quite a few. Even had an AU111 on it's third radiator & second trans - all changed by Ford, first under warranty, second partial payment, third full customer payment. Each radiator was meant to have been "updated".
Maybe it's electrolysis, or a crack. But then why does it seem that the majority are vehicles that have not had a coolant change?
Like I said just guessing.
Old 06-03-2014, 11:04 AM   #16
johnydep
johnydep's Avatar
See above.
Plus; unless using high magnification, corrosion of metal could start a crack from weakness and fatigue.
Old 07-03-2014, 11:53 AM   #17
GT2
Ford customer care were on to this rather quickly. Service and communication was very good as was the dealer. They have agreed to cover the cost.
Old 11-11-2014, 02:59 PM   #18
GT2
6 month/5000km later and the exact same thing has reoccurred.
Old 11-11-2014, 03:07 PM   #19
Our MA did the same thing a couple of years ago. We were out of warranty too but the car had only done 20000km. They huffed and puffed but eventually fixed it for us.
Old 11-11-2014, 03:23 PM   #20
XR Martin
XR Martin's Avatar
Stray current in the coolant and earthing against the block, will eat through aluminium in no time.
2004 BA wagon RTV project.
XR Martin is online now   Reply With Quote Multi-Quote with this Post
Old 11-11-2014, 03:23 PM   #21
mik
mik's Avatar
i wonder if any one has ever tested the quality of the coolant/inhibitor that goes into these these things, aluminum is a very **** weak metal when it comes to with standing corrosion/electrolysis attack.
Old 11-11-2014, 11:11 PM   #22
mighty-mon
mighty-mon's Avatar
Hmmm ....i think our 2010 MB XR5 might have this problem as im sure we may be loosing coolant ever so slightly at the moment. Will have to keep a close eye on it from here on in.
mighty-mon is offline   Reply With Quote Multi-Quote with this Post
Old 12-11-2014, 11:00 AM   #23
mik
mik's Avatar
Maybe that's something else to contemplate , despite dealer or workshop x doing the service what are they putting in , and what is going in at the factory?
i pulled the cooler out of the bottom tank of my AU radiator when the core failed , and the cooler actually looked decent Qaulity brass, not sure what they use these days.
Old 12-11-2014, 01:32 PM   #24
Deo
Deo's Avatar
Very interested to hear if they pay for it given the original repair was ex gratia.
They damn well should particularly given Martin's suggestion that the root cause wasn't fixed.
Sent from my GT-I9305 using Tapatalk 2
_ __ __ __ __ __ __ __ _
_____________________
2010.11 Mondeo Titanium
MC Ink Blue Diesel Hatch
Deo is offline   Reply With Quote Multi-Quote with this Post
