Old 18-04-2014, 06:42 PM   #1
hales231271
hales231271's Avatar
Default AU ute qtr window surround trim removal
Can anyone give advise on how to remove the plastic surround trim without breaking it?
I am reluctant to remove but if possible without damage I will remove.
hales231271 is offline   Reply With Quote Multi-Quote with this Post
Old 18-04-2014, 07:45 PM   #2
LeadFoot81
_Oo===oO_
LeadFoot81's Avatar
Default Re: AU ute qtr window surround trim removal
There are two plugs on the inside of the trim, these just click in/out. However there is also sikalfex holding it in place.
You have to *very carefully* slice the sikaflex while gently prying the b pillar trim away from the window.
Be careful, as it's very easy to bend the plastic trim!
I've attached pics of the b-pillar with trim removed, I'm not sure if every ute released has the sikaflex in the same spot, but it's probable.
LeadFoot81 is offline   Reply With Quote Multi-Quote with this Post
Old 19-04-2014, 09:35 PM   #3
hales231271
Thanks for the advise.
Following this I removed the surround without damage.
You can see why the sikaflex has to be sliced with a sharp knife or damage occurs.
Dazza
