Old 11-07-2014, 11:06 PM   #1
Ramo
Default Mk2 Escort wiring issues
Hi. I'm restoring my 2.0ltr Mk2 Auto and all my labels have faded! Im particularly interested in the wiring that goes to the starter motor and also the alternator. I need the colours and connection types. Some are obvious so are not. The manual I have, have completely different colour codes!
Thanks in advance
Ramo is offline   Reply With Quote Multi-Quote with this Post
Old 12-07-2014, 10:47 AM   #2
russellw
Chairman & Administrator
russellw's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: Raptor: For Continued, and prolonged service to the wider Ford Community
Default Re: Mk2 Escort wiring issues
There are (unfortunately) two different sets of colour codes for pre 6/77 and post that date models. Let us know which you have and I'll see what I have.
Russ
__________________________________________________
Observatio Facta Rotae
russellw is offline   Reply With Quote Multi-Quote with this Post
Old 13-07-2014, 01:29 AM   #3
Ramo
Thanks for that Russ. The build date on the plates is 09/77 4 door auto. It also looks like they fitted a relay in the engine bay for the auto only, and would like to replace it for a new one as the old ones is in poor condition. I need to know what amp rating it is its only got 4 pins, so I'm assuming its a single pole single throw?
Old 13-07-2014, 10:51 AM   #4
russellw
russellw's Avatar
If you take the relay out it should give you some details on rating but yes, it should be single pole, single throw.
I've got the earlier manual unfortunately but I can still probably help with the alternator wiring as they were pretty standard across a lot of models based on whether they are made by Denso, Mitsubishi or Fema.
Can probably help with starter too if you can tell me whether it is 3 or 4 wire connection.
Russ
Old 13-07-2014, 04:41 PM   #5
Ramo
Thanks Russ.
Problem is the relay is a metal one and so corroded I can't see any ratings. The starter motor has one M8 size bolt and 2 male spade connectors. The M8 bolt has the main thick red lead from the battery, but I think theres another smaller red wire too. I know the bottom spade connecter is the black wire and I think the top spade connector has two wires on one spade and I think its red and green. Any help would be great.
Old 14-07-2014, 07:18 AM   #6
russellw
russellw's Avatar
The M8 bolt is correct - it supplies battery feed.
Red/Light Blue wire supplies 12 volts
Red/Light Green wire supplies switched 12 volts
If yours has a ballast resistor wire as well (goes to a ceramic resistor) the Red/Light Green wire goes via it (red only for 78-80 models) to reduce 12V down to 7.5V. The wire goes from the second spade connector on the starter motor then splits out to the fuse block and then to coil.
Russ
Old 15-07-2014, 10:21 PM   #7
Ramo
Thanks Russ,
Most of what you said is spot on except the Red/light blue(not sure about that wire at the mo, the only Red/light blue seems to be the switched wire for the relay, which then becomes a black wire via a spade connector. I've drawn a little diagram, I'm hoping its correct as it is, so I don't have a fire!
hand drawn wiring.pdf
Old 16-07-2014, 05:47 PM   #8
russellw
russellw's Avatar
That looks right from what I can see - looks like some of it has been replaced from the join onwards. Might be a good idea to fit a quick disconnect on the battery and have someone handy when you try it.
Russ
