Old 03-09-2014, 11:55 AM   #1
HH3
HH3's Avatar
Default 2007 Focus LT fascia problem
I just switched out my stock head unit for a Kenwood dpx u5130bt unit.
After wiring it up and modifying the original Focus brackets, its fits great and is very solid.
The problem I have is the fascia I got does not fit into the space around the head unit. Apparently the unit is not regular 2 Din size, but it fits perfectly using the original brackets, so I am at a loss.
Also, I have tried to contact multiple places about getting something to fit, with no avail.
Does anyone have any ideas or solutions?
HH3 is offline   Reply With Quote Multi-Quote with this Post
Old 03-09-2014, 02:42 PM   #2
Franco Cozzo
Thailand Specials
Franco Cozzo's Avatar
Default Re: 2007 Focus LT fascia problem
Where is it not fitting? Around the edges of the head unit? You might be able to lightly file/sand it out bigger without butchering it to fit if thats the case.
If it wont clip in, then you might need to find an aftermarket facia.
Old 03-09-2014, 02:45 PM   #3
HH3
HH3's Avatar
I have the aftermarket one, but its too thick on the sides, and not thick enough on the top and bottom.
I have thought about trying to modify it, but its never gonna look like its supposed to be there.
Hopefully I can find one somewhere, Ive been looking a lot for about 2 weeks now.
Old 07-09-2014, 11:46 AM   #4
leakey
leakey's Avatar
Try these.
http://www.ebay.com.au/itm/Radio-Fac...item2ecb6ca7f7
http://www.ebay.com.au/itm/MES-Celsu...item1c42fa3c86
You can also swap the whole fascia.
http://www.ebay.com.au/itm/Autoleads...3D121382780038
XG Falcon Ute, XE Fairmont Ghia & BA Mk II Falcon SR
leakey is offline   Reply With Quote Multi-Quote with this Post
Old 08-09-2014, 03:23 PM   #5
HH3
HH3's Avatar
Ok thanks. Ill have a look.
