Old 07-10-2014, 07:29 PM   #1
ozeford
EBBA
ozeford's Avatar
Default AU1 Wagon Remote lock no indicator flash?
Hey guys, have a AU1 Wagon which has smartlock of course, I've notice that the indicators don't work when I lock it, the parts car which was also a AU1 with smart lock did, does anyone know what makes the indicators work or 2 stop working?
would like to get them to work again so I can see when its locked from distance etc etc..
Thanks.
My Rides I've Own
94 EF Fairmont Sedan
93 EB GLi Sedan
97 EL Wagon
95 VS Exec
99 AU1 Forte Wagon - Current Daily
Next
XH T5 Ute (Daily/Work Ute)
XG Ute (drift/skidpan project)
ozeford is offline   Reply With Quote Multi-Quote with this Post
Old 08-10-2014, 08:57 AM   #2
Maka
Au Falcon = Mr Reliable
Maka's Avatar
Default Re: AU1 Wagon Remote lock no indicator flash?
Have you removed the blinker flasher & swapped out with another known good one yet?
cheers, Maka
Old 08-10-2014, 10:02 AM   #3
Gothefalcon
FAWD - No Boundaries
Gothefalcon's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: He takes long trips in his AWD Falcon & where ever he goes he sets out to meet forum members at various destinations. He does this without expectation of any sort. I have had the pleasure of spending time with Dhru on two of his separate trips and his gre Technical Contributor: For members who share their technical expertise. - Issue reason: The excellent write ups in your BF AWD Falcon Wagon thread
Howdy, The BEM (Body Electronics Unit) controls this. I have an NL Fairlane which stopped flashing the RH indicator when locked/unlocked years ago.... then about a year ago it stopped altogether for a while... and now its one side of the other ! Hasn't affected anything else yet... so haven't worried too much about it.
You could try swapping the BEM out of the donor car... I think it can be done without Ford's help in the AU !?? Don't quote me though !
Dhru
View My Build thread
22 DJR Shell V-Power Mustang Eskymobile (my first EV)
07 BF2 AWD Falcon Wagon (Daily driver)
04 BA Falcon 1Tonner Ute (New Project)
03 BA Falcon Wagon (Spare)
98 NL Fairlane Ghia V8 (Weekend cruiser)
70 VG paddock racer (Cain it til it breaks.. fix it.. Cain it all over again !)
Gothefalcon is offline   Reply With Quote Multi-Quote with this Post
Old 09-10-2014, 12:29 AM   #4
ozeford
EBBA
ozeford's Avatar
Yeah replace flasher relay but didn't work, and have another bem but not the key and barrel that came with it.
May just have to wait when I do a Fairmont Gita dash swap
My Rides I've Own
93 EB GLi Sedan
97 EL Wagon
95 VS Exec
Next
Old 09-10-2014, 12:57 AM   #5
11ford11
try wriggling connections at bem
if new BEM is same as old one replace and turn key on reds for approx..30min to download key to bem should start after this then key to accessory within 5 seconds switch demist switch 3 times push any button on remotes -
11ford11 is offline   Reply With Quote Multi-Quote with this Post
Old 09-10-2014, 04:04 PM   #6
ozeford
EBBA
ozeford's Avatar
Ok will try that and see how it goes thanks
My Rides I've Own
93 EB GLi Sedan
97 EL Wagon
95 VS Exec
Next
Old 09-10-2014, 07:49 PM   #7
ozeford
EBBA
ozeford's Avatar
Tried it didnt work, would only crank over but not start after waiting 30mins.
But flashers did work when I swapped it (remote came from the spare au car)
My Rides I've Own
93 EB GLi Sedan
97 EL Wagon
95 VS Exec
Next
Old 09-10-2014, 11:48 PM   #8
11ford11
same procedure but - close doors - window down- extend time to 65-70 minutes locks should cycle -ignition off 10sec. then try-
is there a smartlock or smartshield warning light or none ??
Old 10-10-2014, 01:26 AM   #9
ozeford
EBBA
ozeford's Avatar
Ok will try again tomorrow, smartlock (99 model) was flashing fast.
My Rides I've Own
93 EB GLi Sedan
97 EL Wagon
95 VS Exec
Next
Old 05-06-2021, 03:13 AM   #10
TECHNO489
Exclamation Re: AU1 Wagon Remote lock no indicator flash?
I know this is an old thread but I have hope
Did you ever solve your problem with the indicators not flashing?
Mine stopped working after 19 years of working for no good reason about a year ago.
I have changed the relay, no luck.
My Central Locking still works fine it's just the lights no longer flash
when locking or unlocking the car.
I want to check the connections on the Central Locking ECU but I don't know where to find it so again I hope maybe you can help me out with that as well.
TECHNO489 is offline   Reply With Quote Multi-Quote with this Post
Old 05-06-2021, 10:49 AM   #11
11ford11
Post 7 indicates flashers worked when bem was swapped don’t know the results however?
Bem is above h/brake area and controls flashers when remote is used as well as central locking and many other functions try wriggling connections
You may find removing bem and carefully resoldering pins on circuit board fixes problem or you may need to replace bem
Prior to 6/99 smart lock system and only requires ignition on 30 to 60 minutes to program after this it is smart shield and requires scan tool to program 2 keys etc.
Old 05-06-2021, 12:49 PM   #12
TECHNO489
Thanks for a quick reply mate, I will try and remove it as soon as I can to check connections and solder if needed.
