Ex-xwc4351
My mothers drivers side seat belt stork/latch button is broken & needs replacement. I have been quoted $65 from wreckers for a replacement. I have done this job to my wifes 2001 laser recently so know how & what needs doing. Problem is my brother inlaw is a spare parts manager for a car firm & he seems to think there could be a problem with a second hand unit not allowing the air bag to deploy in a crash (belt tension sensor?). Has anyone heard of this or are there any other issues I should be aware of ?? Thanks in advance
My previous rides 1st -LC Torana 186S Manual 2 Door ![]() 2nd -XC Falcon GS 302 Manual 4 Door 3rd -Mazda RX4 12A Manual 2 Door ![]() 4th -Mk 2 Escort 2lt Manual 2 Door 5th -EA Brock Falcon 3.9lt Manual 4 Door 6th -Mk 2 Escort Ghia 2lt Manual 4 Door 7th -1985 C4 Corvette 350 Auto 2 Door ![]() 8th -BA SR 2005 4lt Auto 4 Door 9th -XW Falcon 1970 351C Auto 4 Door 10th -XC Falcon GS 351 Manual 2 Door ![]() 11th -BF II XR8 2007 Auto 4 Door 12th -2009 SY II Territory Ghia Turbo |
Chairman & Administrator
![]() ![]() Join Date: Dec 2004
He is probably referring to the pre-tensioner which is wired to the base of the seat frame and must be refitted when the buckle is replaced.
Cheers Russ
Observatio Facta Rotae
Ex-xwc4351
"He is probably referring to the pre-tensioner which is wired to the base of the seat frame and must be refitted when the buckle is replaced."
Thanks Russ Is the pre tensioner part of the replacement buckle & will I be able to tell if the pre tensioner has gone off in a crash?
The pyrotechnic pretensioners for the driver and front passenger safety belts are incorporated into the safety belt buckle stalks.
Refer to the diagram below. Cheers Russ
