Old 13-06-2015, 11:11 PM   #1
XF_Pilot
Default Will AU brake lines fit BF-FG brakes on my AU XR8
Hi everyone,
I have an AU 2 XR8 with an FG front brake upgrade kit (322mm). It has standard AU rear brakes.
I want to put stainless steel brake lines on it. My question is are the BF-FG lines and threads etc the same as the twin piston AU brakes.
If so can i just buy an AU stainless brake hose kit and fit it?
XF_Pilot is offline   Reply With Quote Multi-Quote with this Post
Old 14-06-2015, 02:22 PM   #2
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
Default Re: Will AU brake lines fit BF-FG brakes on my AU XR8
I have put BF XR 322 on my AU and used the standard AU XR8 on mine they just make the length, I bent the cable holder on the shock a little bit, they still have movement when the wheel is full turned. Haven't fitted the rear so can't help there.
UK
Old 16-06-2015, 09:19 PM   #3
XF_Pilot
Thanks. Thats positive.
Also are the rears on AU and BF the same? Meaning could i buy a BF+ kit?
Old 16-06-2015, 10:24 PM   #4
Uncle_Ken
Uncle_Ken's Avatar
Cool Re: Will AU brake lines fit BF-FG brakes on my AU XR8
Here you go
UK
Old 18-06-2015, 09:45 PM   #5
XF_Pilot
Thanks. Which rears are you using?
Old 18-06-2015, 10:51 PM   #6
Uncle_Ken
Uncle_Ken's Avatar
I'm looking at Terry 328*26 but not sure if they are worth it. Standard BA rears are a bit larger and cheaper to fine.
UK
Old 19-06-2015, 09:01 AM   #7
XF_Pilot
Thanks. Do the BA brakes require any mods like the BF rears do?
Old 19-06-2015, 06:23 PM   #8
Uncle_Ken
Uncle_Ken's Avatar
No I dont think so BA's are smaller, only 303*16. They should be an easy swap with 17" mags and above
UK
