Old 02-02-2016, 07:57 AM   #1
Katoomba
Default What is this part in spare wheel compartment?
I haven't been to the forum for a quite a while now. I'm still driving my build date Nov 2007 Mondeo Zetec. I like this car so much I just don't want to part with it. Definitely the best car I've owned in over 50 years of driving and nearly as many cars.
Anyway, today I went out the front and I've got my first flat tyre in many, many years. I prayed that the mechanics had put the wheel lock nut back in at the last service. No problems, the lock nut was there and the nuts weren't too hard to loosen. I can see at least three nail-like pieces of metal in various parts of the tyre.
Now to the point of this point: what is this part that was in spare wheel compartment alongside the jack and wheel brace? It's not mentioned in that poor photocopy-quality excuse for a manual that new Mondeo owners were given in 2008 when I bought the car.
~ Zetec Hatch in Thunder owned since bought new in 2008 ~
Katoomba is offline   Reply With Quote Multi-Quote with this Post
Old 02-02-2016, 08:02 AM   #2
Blue Shadow
R.I.P. Maggie
Blue Shadow's Avatar
Default Re: What is this part in spare wheel compartment?
Tow eye, screws into front or rear of car so it can be dragged without damaging the car
Blue Shadow is offline   Reply With Quote Multi-Quote with this Post
Old 02-02-2016, 08:55 AM   #3
Katoomba
Thank you. After I posted and thought about it, I guessed that might be the answer.
Cheers.
Old 08-02-2016, 05:57 AM   #4
NZ XR6
You will probably never need it, but I got stuck in a wet paddock when I had the MA and we could not figure out where to connect the tow rope ...
MB Mondeo TDCi wagon, sea grey, on MAK Invidia 16" wheels.
NZ XR6 is offline   Reply With Quote Multi-Quote with this Post
Old 08-02-2016, 11:55 AM   #5
SYZ
Beaut Ute
SYZ's Avatar
Why the left-hand thread?
—Cortina Mark I, Escort Mark 2, XR Falcon 500, XE Falcon 4.1 S-Pack, Laser KC Ghia, EF Falcon GLi, BF XR8 Boss 260
SYZ is offline   Reply With Quote Multi-Quote with this Post
Old 08-02-2016, 01:28 PM   #6
MDS69
MDS69's Avatar
Purely a guess but maybe so someone doesn't screw in an un-authorised fitting, so as to limit liability if an incident occurs.
MDS69 is offline   Reply With Quote Multi-Quote with this Post
Old 09-02-2016, 08:43 AM   #7
rondeo
Tow eye can be used with rope to stabilise front of pipes etc on roof rack. Wagon will fit 6m lengths.
rondeo is offline   Reply With Quote Multi-Quote with this Post
Old 09-02-2016, 09:49 AM   #8
GasoLane
Former BTIKD
GasoLane's Avatar
I'm guessing it's not, just that someone's reversed the pic.
Check the scroll on the partially hidden wording.
Old 09-02-2016, 11:03 AM   #9
rondeo
It's LH thread. There's also a little wire tool with a finger hole to open the cover.
Old 09-02-2016, 11:14 AM   #10
SYZ
Beaut Ute
SYZ's Avatar
Looking at the thing, I certainly wouldn't be relying on it as a safe recovery point fitting, especially for use with a snatch strap.
Similar HERE.
Old 09-02-2016, 11:39 AM   #11
olfella
Cranky old bastard
I am thinking that it is because the attachment and where it attaches are made for one reason - to tie the car down or tow. And not to attached other 'unauthorised' attachments like a bike rack etc. Another way of a get out clause made by lawyers.
"But really...what can possibly go wrong"
olfella is offline   Reply With Quote Multi-Quote with this Post
Old 09-02-2016, 11:58 AM   #12
99AUXR
Brad
99AUXR's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Installing starter motor advice on ba / bf 6cyc Falcon.
Its not a point to use snatch straps or any shock loading it is designed to be pulled by a winch. Have seen people pull bumpers off cars due the it tearing out welds on some models due to the above.
Silhouette BF MKII F6
Plazmaman Intercooler Kit, ID1000, 34mm Internal Wastegate and Turbosmart Actuator, Tein Coilovers, Focal Audio, XXR 521 18x8.5 18x10
99AUXR is offline   Reply With Quote Multi-Quote with this Post
Old 09-02-2016, 05:44 PM   #13
rondeo
The tow eye also screws into the wheel brace to act as an extension/knob.
The user manual says it is to be used for towing but not with a rigid tow bar, and the obvious fact that too much tension could damage either vehicle.
Old 09-02-2016, 05:50 PM   #14
Blue Shadow
R.I.P. Maggie
It should be used to drag the car on to a tilt tray tow truck, you remove the bar cover cap and it screws into the body normally the bar reo. That is what they were desigened for.
