Old 10-09-2016, 07:07 AM   #1
riverrat321
Default Anyone driven a twin turbo ve ss?
Hi guys,
I know it's not a holden forum but for something different I'm considering looking for a twin turbo ve ss. Has anyone driven one? Wondering how they compare to a xr6t.
riverrat321 is offline   Reply With Quote Multi-Quote with this Post
Old 10-09-2016, 08:03 AM   #2
Stefan
Stefan's Avatar
Default Re: Anyone driven a twin turbo ve ss?
Did Holden build a twin turbo SS?
Stefan is offline   Reply With Quote Multi-Quote with this Post
Old 10-09-2016, 08:06 AM   #3
Sioso
irregular member
Sioso's Avatar
I haven't driven one but a well known tuner in NSW took me for a ride in a customers VX GTS with a Gen TT kit installed.
It sounded like jet taking off every time the boost came on and the scenery turned into a blur.
Still had the V8 rumble at lower revs which was then drowned out by turbo scream as boost came on.
I think it was somewhere around 400rwkw and even though I've had 4 modified turbo Falcons none of them were making that much power so I can't really compare.
The noise in the GTS was definitely better.
I was impressed!
Sioso is offline   Reply With Quote Multi-Quote with this Post
Old 10-09-2016, 08:11 AM   #4
riverrat321
Thanks heaps Sioso. That sounds like what I'm after. I love the v8 sound and love how turbos sound as well so sounds like it would be the best of both worlds. My old xr6t with 310 rwkw was a really fun car to drive the way it come on boost and hit hard. Never been too into holdens but this could be a fun change for a while. There is one I want to look at but its hours away and I just need to find time.
Old 10-09-2016, 08:20 AM   #5
blackf6
R51 Pathy, 91 Jayco Swan
blackf6's Avatar
Turbo a v8 Falcon.
blackf6 is offline   Reply With Quote Multi-Quote with this Post
Old 10-09-2016, 08:29 AM   #6
riverrat321
Been keeping an eye out but they are very hard to find and I want to buy one already done.
Old 10-09-2016, 08:46 AM   #7
roddy1960
roddy1960's Avatar
Originally Posted by blackf6 View Post
Turbo a v8 Falcon.
G'day all...Brings me to ask is there a technical reason why our V8 is supercharged , not turbocharged ?
The Stang is capable of being turbo'ed I believe. Got to say though , it'd take a lot of impressing me to go away from the super'ed Coyote 5.0 or the turbo'ed Barra but if a General V8 with a snail thing or blower does it for you , I hope you find a good 'un that you'll have a ball with..Good hunting...Cheers Rod.
roddy1960 is offline   Reply With Quote Multi-Quote with this Post
Old 10-09-2016, 01:50 PM   #8
Mercury Bullet
Yep. Drivability.
In something like a boat where you are in boost 99% of the time they are a brilliant engine.
www.bseries.com.au/mercurybullet
2016 Falcon XR8. Powered by the legend that is - David Winter.
XC Cobra #181.
1985 Mack Superliner, CAT 3408, 24 speed Allison.
Mercury Bullet is offline   Reply With Quote Multi-Quote with this Post
Old 10-09-2016, 11:04 PM   #9
Mechan1k
Mechan1k's Avatar
Originally Posted by Mercury Bullet View Post
Yep. Drivability.
That and the packaging as well of the supercharger on top ... trying to find space for turbo(s) and plumbing around a BOSS/Miami engine is harder than say an I6 motor.
It can be done ... but from the Factory perspective the superchrger is a neater package ... and the drivability as mentioned before too.
Old 10-09-2016, 11:18 PM   #10
I know an air con guy who put twin turbos on his ve 2 malloo. Can't tell you how good they go once run in as he had to sell it for a 7 seat Prado before it was run in due to upcoming family constraints, but taking it easy on the thing, all I hear was it was a bullet. It was apparently the 800kw kit with the obligatory built motor and cost a bomb. The malloos budget friendly work replacement of a hilux seems kind of limp wristed
.:4:. is offline   Reply With Quote Multi-Quote with this Post
Old 10-09-2016, 11:32 PM   #11
SprintFg
Not much room under a ford falcon v8 Bonnet. Turbos and their plumbing would be a huge headache and create so much heat.
Supercharger sits right between the V, like a hand in a glove. Great packaging. Provides just as much benefit as turbo for factory complianced car as well as they would only ever run moderate boost.
SprintFg is offline   Reply With Quote Multi-Quote with this Post
Old 11-09-2016, 12:15 AM   #12
gilly2497
I had a VE sedan with twin turbo setup with water injection and upgraded fuel system, injectors exhuast etc to suit.
Conservative boost made a tad over 415 rwkw.
was fun to drive as you could lose traction at around 80 - 100km/h but was also very sedate if you wanted it to be.
Looked standard and was nice and quiet. Fuel economy improved quite a bit if taking it easy.
Sold mine due to boost pipes blowing off all the time and it just gave me the *****.
Much happier with the fgx xr8 .. not as much power but has the ability to put the power to the ground and therefore a tad quicker at normal speeds.
The VE pulled like a train when the boost kicked in and just kept on going.
gilly2497 is offline   Reply With Quote Multi-Quote with this Post
Old 11-09-2016, 09:42 AM   #13
riverrat321
Thanks heaps guys. I also have an fgx xr8 sprint and being a sprint I don't really want to modify it. I also miss the feeling of a turbo. There seems to be heaps more room in a ve engine bay that's for sure. Would have been fantastic if they did a twin turbo from factory with the xr8.
Old 11-09-2016, 09:53 AM   #14
JC
JC's Avatar
Dan (CAT600) has turboed a supercharged falcon. From the top, looks stock. Spits out roughly 1000HP at the wheels on E85 though.
http://www.fordforums.com.au/showthr...33#post5761433
Ford Performance Club ACT
Old 11-09-2016, 11:58 AM   #15
STINKY NINJA
If someone was selling 5g turbo kits for v8 falcons like the entry level goat kits there would be boatloads of them around.
STINKY NINJA is offline   Reply With Quote Multi-Quote with this Post
Old 11-09-2016, 12:41 PM   #16
riverrat321
That kit from Dan looks really interesting!
Old 11-09-2016, 01:45 PM   #17
JC
JC's Avatar
What's a goat kit? Not sure if you're kidding (pun intended)
Old 11-09-2016, 02:14 PM   #18
nstg8a
3..2..1..
nstg8a's Avatar
Heaps more room in a commodore because the Ls is only 2/3rds the size of a coyote.. That's why they're so popular for conversions. Small light motor but big displacement. Polar opposite of the coyote/Miami
Originally Posted by pottery beige View Post
Happy mcgadget meal orphan mcboofhead
nstg8a is offline   Reply With Quote Multi-Quote with this Post
Old 11-09-2016, 04:21 PM   #19
gcg2503
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Always adding valued comments,  never involved in any disputes. A credit to this forum.
Forum member Uncle Tone has a twin turbo VE GTS
Maybe shoot him a pm
gcg2503 is offline   Reply With Quote Multi-Quote with this Post
Old 11-09-2016, 06:08 PM   #20
STINKY NINJA
Advertised in street machine I think,pretty sure its goat performance.
Its actually the v6 kit for 5g ,the v8 starts at $5500 which I think is a great price.
Google goat performance.
Old 11-09-2016, 06:37 PM   #21
F6RCD
Anyone heard anything about these goat kits? any good? theyre very cheap.
F6RCD is offline   Reply With Quote Multi-Quote with this Post
Old 11-09-2016, 07:04 PM   #22
SpoolMan
Solution Was Boost 4?, 6 & 8
SpoolMan's Avatar
Hi guys,
Autotech sold these in a fitted kit, I drove one many years ago for 3 days whilst they were working on my F6.
For city driving and a daily driver I preferred my BF F6, lighter over the the front and more nimble, the VE had brass button twin plate clutch not very friendly to Sydney's traffic congestion.
From Autotech Granville website
http://www.autotechengineering.com.a...Commodore.html
[SIGPIC][/SIGPIC]
SpoolMan is offline   Reply With Quote Multi-Quote with this Post
Old 11-09-2016, 09:47 PM   #23
Nu66et
You should look at what the likes of Porsche and Mercedes Benz are doing on their current turbo V8's. Reverse flow heads allowing 2 small turbos in the engine valley and still punching over 400kw for some models from 4L. Hopefully Ford consider that direction for any new generation petrol V8's, theyve been doing it on their PowerStroke diesels for awhile.
Nu66et is offline   Reply With Quote Multi-Quote with this Post
Old 11-09-2016, 11:08 PM   #24
riverrat321
How did the power delivery compare spoolman?
Old 11-09-2016, 11:21 PM   #25
Mechan1k
Mechan1k's Avatar
Yeah i know ... no real room in the bay ... I guess that's why he mounted them that low and that far back.
Old 12-09-2016, 09:23 AM   #26
FG50T
FG50T's Avatar
Driven a single turbo which I liked the drivability of. Been for a ride in a twin and it was a bit more manic and a touch more torquey imo. I'm sure the manicness can be tuned out or related to the cam too but turbo Holden V8's are good things! Must be backed by a turbo400 imo though.
FG50T is offline   Reply With Quote Multi-Quote with this Post
Old 12-09-2016, 09:45 AM   #27
Sprint
Sprint's Avatar
have you driven a quad turbo falcon?
Sprint is offline   Reply With Quote Multi-Quote with this Post
Old 12-09-2016, 09:48 AM   #28
Vesper Martini
Vesper Martini's Avatar
The cheapest factory twin turbo v8 must be the C63?
you can get a 2015 model for around $160K. 380KW 500NM 4 sec car.
______________________________
2015 Territory Titanium RWD Diesel - SOLD
2016 BMW X5 xdrive 30D Msport
Seadoo Challenger 210SE 310HP
Vesper Martini is offline   Reply With Quote Multi-Quote with this Post
Old 12-09-2016, 12:06 PM   #29
Express
Bathed In A Yellow Glow
Express's Avatar
The Newton metres you've quoted is wrong.
The C63S as sold in Australia is 375kW and 700Nm with a 4 sec 1-100.
Even the old base N/A models started with 600Nm.
It plus the 255 wide rears on the last model is the reason they get out of shape so easily when the traction is switched off.
Express is offline   Reply With Quote Multi-Quote with this Post
Old 12-09-2016, 12:29 PM   #30
Express
Express's Avatar
I had my VE Ute twin turboed in 2007 after driving a couple and thinking they were such a rush.
It was a manual with the turbos mounted under the engine which made for a very stealthy look but I found the power delivery to be severe.
As there is far more tuning knowledge with them these day that problem has possibly been rectified to some extent and as much as it pains me to say, an Auto may also be a better way to go.
At the time it was also a cheaper alternative to a supercharger.
I’m sorry I sold it but unless you want to impress with a big output number I’d prefer to go with a blower these days as they offer very streetable power and if you’re not taking it racing who is really going to care which delivers the most power.
Personally I love and prefer the slower N/As with noticeable cams but they can be so in your face.
