Should the oil change warning display without exception once oci has been set on the vehicle?
Don't know but it's very easy to reset in a MC mondeo:
Turn off the ignition. Close all doors. Turn the ignition key to position II. Simultaneously press the accelerator pedal and the brake pedal and hold for a minimum of 20 seconds. The oil change reminder indicator should turn off. This confirms that the reset procedure has been correctly completed. |
#3 | |||
It can come on also if you have too many failed DPF regen cycles, but I think that was only a problem with the early diesel Mondeos in Europe. Sent from somewhere using Tapatalk
