Hey im just wondering how to replace the low beam headlights on xr8...will the headlights off a EB,ED tickford front end, coz they have the round quads as well,so will it have the same wiring loom plug as the xr AU an can it be used
[B]WTB (Syd)...AU 5.0 or xr8 4 speed auto transmission in good working cond /B] |
#2 | |||
AU DIE HARD
![]() ![]() Join Date: Nov 2005
Probably could be done, but are a much different size light and would look a bit odd, That and the low beam on the AU is also the part of the hi beam set up
........Age and treachery will ALWAYS overcome youth and skill....... CORTINA 250 2V POWER soon to be AUXR8 Windsor pwrd .............WINDSOR WARLORD WHO CARRIES THE CLEVO MAFIA AND BROKEN BOSSES... ......................... Quote:
are they the same size as the au low beam lights.
What do you mean part of the low beam setup
The earlier XR's had projector style low beam lamps, while the AU's had a reflector headlamp.
If you're just replacing lamps due to damage, this might help you: http://www.fordmods.com/ford-bodykit...e-t130945.html |
#5 | |||
AU DIE HARD
AU main light is a H4 Hi/Low beam globe inner light is a spot light
