Smart charge failure 160000 km?
Seeing a small acid leak from the battery vent I plugged a DVM into the cigar lighter. Voltage remains more or less constant somewhere between 14.4 and 15.2, depending on temp (lower as temp goes up), and up and down slightly as engine revs go up and down. Smart charge is meant to do the opposite, up to about 15v downhill and down to about 12.5 when accelerating, as I have verified on my other car. I read somewhere the alternator defaults to a fixed charge voltage when smart charge fails. I'm getting overcharge though. Possibles causes are alternator, wiring or PCM. Alternator about $800. Pays to check the battery compartment as there may be no indication to the driver via dash lights. Last edited by rondeo; 18-04-2017 at 12:58 PM. Reason: correction |
Is the battery OK? From my observations when the OE battery was dying, the system keeps charging if the battery voltage drops too far when the alternator shuts off.
Sent from my SM-G9208 using Tapatalk
PS I suspect it is still working because you are seeing over voltage. If it had failed, then I expect that you'd see a constant voltage of 14.4 V.
#4 | |||
Passed a battery test at battery shop OK, conductance and carbon pile. While driving the voltage is constant at values mostly 15,14.6,14.4 but never goes below as I think it should with smart charge which goes up and down constantly. Test should ideally be Ford IDS or auto electrician with expensive OBD. There is a test box for the 3 wire regulators which can command the alternator to output specific voltages. None of the auto electricians I spoke to had a one wire LIN tester only the three wire. Forscan has no PID for commanded generator output as far as I see, just state of charge. Which is currently 80%, exactly as it should be. Will keep an eye on it for a while . . . |
does it have a sensor on the neg battery terminal? on my ranger i could disconnect that and then the alternator defaulted to standard alternator behaviour - be a good test?
2015 Toyota Landcruiser 79 V8 SC |
Yes there's a battery sensor on neg terminal but not easy to bypass.
You gave me an idea though, I'll see what happens when I disconnect the LIN control wire from the alternator. It should default to a fixed voltage. Currently it will stay fixed at 15v for 40 minutes at a time (round trip to town). |
Disconnected the LIN regulator control wire.
System voltage defaults to 13.8V max. Fault code in PCM: P1632:08-2C Smart Alternator Faults Sensor/Circuit Bus signal/Message failures. Some Googling, the only smart regulator tester I could see: http://autodiagger.com/autodiagger-a...FVcmvQodorwG2g And the old BMS question, in post #6: http://www.explorerforum.com/forums/...es-why.404981/ Last edited by rondeo; 20-04-2017 at 10:36 AM. Reason: addition |
"Fault detection includes Mechanical Fault, Electrical Fault, Thermal Fault, LIN Bus time-out, Comm error and LIN protocol errors. The extensive diagnostics that the IC provides shows how far a digital-controlled alternator has progressed beyond the simple idiot light of analog control."
I'm thinking I'm the idiot here. Googling I came across the above which shows how complex charging systems have become: http://www.eenewsautomotive.com/cont...harging-system I reconnected the LIN bus and the voltage stayed at 14.4 for the run to town. I'm looking suspiciously at the battery current sensor on the negative terminal . . . there's a PID in Forscan called 'Battery amps'. 'Battery amps' wouldn't make sense in this context, given the number displayed is 465500. Not sure what it means. Less complex explanations here: http://www.motoplat.nl/Tech%20Info/E...Alternator.pdf Last edited by rondeo; 20-04-2017 at 08:16 PM. Reason: addition |
Wow, that's a bit more complicated than I expected.
I expect the BMS learns the new battery behavior after a while, so while the reset would be nice to do, it's not essential. Interesting thing with my wagon was I don't recall the fuel consumption dropping when stopped at the lights before replacing the OE battery with a Century.
I was at Jaycar and bought a ciggy lighter DVM. Not impressed though, it's angled for LHD and the V symbol obscures the tenths digit. Might return it after a few days ...
Well, during a 15 minute drive, mine sat at 14.4 - 14.7 V all of the time, even when the fuel consumption at idle dropped. Is there any other energy saving measure that could account for that drop in consumption? I turned on every electrical load I could at idle, and it never went below 14.4. One other observation is that I've never seen the headlights dim at night, which you would expect if the voltage dropped to 12.5. So does the low voltage only occur if the headlights are off? Lots of questions and not much information. I suspect that the charging system is smarter than us!
At least the LX is running fine despite doubts about the charging system. Not too worried about, just puzzled.
It behaves in a totally different way to the zetec which always shows the voltage going up and down between 13.5 and 15V. I have a nice Fluke voltmeter with min and max which beeps when a new value is stored, so I don't need to watch it all the time. Once on a 30km trip the LX suddenly started doing what the zetec does, for about 5 minutes, then went back to the fixed voltage. Im not sure what you are referring to when you say the fuel consumption drops at idle, is that when you switch off a load? |
#12 | |||
Do you have different batteries in the LX and Zetec? I've checked the ciggy lighter DVM, which reads 0.23 V high - another reason to return it. So the voltages are more like 14.2 - 14.5. I'm going on a trip next week, so hopefully might see more interesting behavior. Where is the current sensor? I can't see anything on either terminal, unless it's hidden somewhere on the -ve cable.
There's a Varta F18 ($320) on the zetec and a Bond 467 SMF ($270) silver calcium on the LX.
The current sensor is on the negative terminal concealed by the fixed battery cover. |
#14 | ||
Original Ford system overview Mondeo 2007.5- (BCM=GEM):
Description and Operation Smart Regenerative Charging Smart Regenerative Charging is an intelligent charge control system that calculates and regulates the set generator voltage. The basic idea of the system is to increase the generator charge voltage when the vehicle is decelerating and reduce it when it is accelerating. This means that during the acceleration phase, there is no additional energy demand as a result of having a high generator load; however generator load is increased when the vehicle is decelerating. This strategy enables further fuel savings to be achieved. Battery Monitoring Sensor The Battery Monitoring Sensor continuously monitors the condition of the battery. The sensor is equipped to vehicles which have Smart Regenerative Charging or Start-Stop. These systems require knowledge of the battery state of charge. The Battery Monitoring Sensor is the sensor used to provide this information. Battery Monitoring Sensor connection The Battery Monitoring Sensor is clamped directly to the negative terminal of the battery and grounds to the vehicle at the chassis ground connection point by means of a thick (25 to 35mm2) cable and eyelet. External customer loads must only be connected to the vehicle at the customer battery connection point. If the external customer load is connected at the negative battery post, the Battery Monitoring Sensor accuracy cannot be guaranteed. It is recommended that the Battery Monitoring Sensor pole clamp is not removed unless a battery replacement is required. Should the battery need to be isolated, this should be done by disconnecting the ground eyelet at the chassis ground. Battery Monitoring Sensor reset The Battery Monitoring Sensor also estimates losses in the battery capacity over time. The Battery Monitoring Sensor should be reset to factory default settings, when the battery is replaced. It is urgently recommended that the replacement battery has the exact same specification as the original battery. If it does not, the accuracy of the Battery Monitoring Sensor outputs will be compromised. The Battery Monitoring Sensor reset is part of the battery replacement procedure in IDS (Integrated Diagnostic System). |
#15 | ||
Original Ford system operation, Mondeo 2007.5- (BCM=GEM):
System Operation Smart Regenerative Charging The largest element of the Smart Regenerative Charging Strategy is stored in the BCM module. It receives all of the important information relating to the battery condition sent by the battery monitoring sensor via the LIN (local interconnect network) data bus. The information obtained is used to calculate the required set value for generator charge voltage. This is sent by the BCM to the PCM via the HS-CAN (controller area network) data bus. This then adjusts the value received if necessary and passes it on the generator via the LIN data bus. The charging voltage is adjusted depending on various parameters, such as the current level of engine efficiency. The smallest possible set value for the generator voltage is 12.2 V, while the maximum charging voltage may be anywhere between 14.5 and 14.9 V. However, when the battery is in a refresh phase, the voltage may occasionally reach up to 15.2 V. These refresh phases are required as the battery charge status is 80% over long periods of time, which increases the risk of sulfation in the cells. Comparison of Smart Regenerative Charging and Conventional Charging Conventional charging aims to charge the battery to the highest possible levels. During this process the battery temperature is monitored and the battery must not be overcharged. By comparison, Smart Regenerative Charging uses the information from the battery monitoring sensor to maintain the battery at a calibrated state of charge (approx. 80%) at all times. This means that the battery has a certain amount of extra charging capacity at all times. If the battery monitoring sensor detects that the charge status is above the calibrated value (approx. 80%), then the generator charging voltage is reduced in order to discharge the battery. If the opposite occurs and too low a value is detected, the charging value is increased in order to return the battery to the calibrated value. Battery Monitor Sensor The Battery Monitor Sensor measures temperature, voltage and current throughput of the battery. It uses this information to calculate the battery SOC (State of Charge). To function with high accuracy, the Battery Monitor Sensor must be recalibrated at regular intervals. A recalibration occurs during a rest period when the battery quiescent current is less than 100mA. This rest period must last for at least 3 hours. The longer the rest period, the greater the accuracy. The timeframe in which a recalibration must take place is seven days. If the system has been unable to carry out a recalibration within 7 days, the SOC accuracy cannot be guaranteed. This will result in the Start – Stop and SRC systems being deactivated. |
#16 | ||
Just to make it complete:
Generator and regulator Description and Operation General information The powertrain control module (PCM) controls the alternator charging voltage. The connection between the PCM and the generator is made via the control module subnetwork (LIN) bus. If the load on the alternator is high, the PCM can increase the idle speed. The alternator is temporarily deactivated during engine starting so that the engine drag moment is minimized and it is reactivated again after the starting procedure. The PCM controls the charge control lamp in the instrument cluster via the controller area network (CAN) bus. Smart Charge system In addition to the familiar functions, the Smart Charge system also performs the following functions: Automatic deactivation of non-critical high power electrical consumers when the battery voltage is low in order to reduce the level of current drawn. Automatic activation of non-critical high power electrical consumers when the battery voltage is excessively high in order to protect components which are sensitive to increased voltages. The battery charging current is optimized through continuous calculation of the battery temperature and monitoring of the alternator output voltage. By receiving the forwarded alternator load signal, the PCM is given early warning whenever an electric consumer is switched on or off. This means that the PCM receives information about imminent changes in the torque drawn by the alternator. By evaluating this information the PCM can provide a higher level of idling stability. The two remaining functions of the Smart Charge System are controlled by the GEM. Electrical consumers are switched off due to low voltage when the GEM determines (on the basis of the message received from the PCM on the CAN bus via the instrument cluster) that the battery voltage has dropped below the threshold. When the threshold for low battery voltage is reached the GEM automatically deactivates the following consumers - in this order and with a gap of 5 seconds between each: Electric booster heater (vehicles with diesel engines) Heated exterior mirrors Heated rear window Heated windscreen If the battery voltage rises back above the lower threshold then the GEM re-enables all of the electrical consumers which were previously disabled. They then have switched off status and must be switched back on by the driver. Electrical consumers are switched on due to excessively high voltage if the GEM determines that the battery voltage is above the threshold for overvoltage and the charge control lamp has been switched on. When the threshold is reached the GEM automatically activates the following consumers - in this order and with a gap of 5 seconds between each: Heated rear window Heated exterior mirrors Electric booster heater (vehicles with diesel engines) Blower motor If the battery voltage drops back below the threshold then the GEM automatically deactivates any consumers that were switched on. However, if they were switched on by the driver before the automatic activation, they will then be switched on again in turn with a 5-second time interval. |
#17 | |||
To sum it up volts on my LX ALWAYS rises slightly on rev increase and vice versa. On the zetec its exactly opposite, always falling on increase in revs and rising on deceleration, by quite a significant amount ie down to 13.8 or so from at or near 15V. |
#18 | |||
I'll see what happens on the trip next week, but I suspect that it will sit between 14 and 14,4 V. I didn't see any sign of the voltage increasing when I coasted a few hundred metres downhill on the motorway, or dropping when accelerating quite briskly.
#19 | ||
I've observed quite a bit about the BMS lately.
If the battery is below 80% it will start charging, steadily reducing the current being fed into the battery until it reaches 80%. Example. If the battery is at 78% it will charge with about 5A. When it's around 67% it will use 20A or more to charge. When it starts to go above 80% the alternator completely stops charging the battery. The current will swing to about -20A (negative to indicate that current is being drawn FROM the battery). At 80% it will swing to charging and discharging the battery to maintain this 80% charge level. This ensures the battery can last many years as the last 20% of charging to 100% is the most damaging for a battery. Symptoms of a failing battery is the percentage charge not increasing by much or fluctuating too much between drives and voltage drastically dropping after the vehicle is turned off. When I replaced my battery with a new one ($130 from Ford Parts Store [E.D]) you HAVE to perform a BMS reset. You can use ForScan to do this via the OBD port. Failure to do this will result in your new battery being charged incorrectly. The BMS stores battery % charge AND how old the battery is in days. An older battery has to be charged differently from a new one and the system is designed to take this into account. |
#20 | ||
Thanks, very informative, hard to believe really!
#21 | ||
Thanks for this info.
$130 for a new battery??? Sent from my SM-G9208 using Tapatalk
#22 | ||
#23 | |||
Plugged the DVM into the zetec again to verify earlier observations. Suprised to find the voltage not swinging up and down as before. So have to retract: 'To sum it up volts on my LX ALWAYS rises slightly on rev increase and vice versa. On the zetec its exactly opposite, always falling on increase in revs and rising on deceleration, by quite a significant amount ie down to 13.8 or so from at or near 15V. ' So in a car with a good battery I'm suspecting the SOC cycle might be slower than I thought, will keep wasting time on it and see. Forscan on android shows 6 digit figures like 163750 while cranking and 473375 while cruising. Units are described as 'Amper'. Can't makes sense of it. stefcio007 where did you find the information that the BMS must be reset? Do you know of information specific to MY2011 TDCi Mondeo? What did you use to check the current? Thanks. |
#24 | |||
BMS reset is listed as a service procedure in ForScan (used PC version) and in Ford IDS. I assume it's the same for the Mondeo. Do you have an extra sensor on the negative terminal cable attached to the battery? If you do then you have a BMS. |
#25 | ||
There's a sensor on the neg battery terminal, all 2007- Mondeos have them, which implies a BMS system.
There is no service function for BMS reset for Mondeo in Forscan. Not all For dealers agree on the need to reset the system. What parameters did you set up as custom PIDs in Torque? Can you link to the thread in the Mondeo forum you mention? |
#26 | ||
Well, no sign of over or under voltage during a 700 km journey. There were slight changes in voltage depending on temperature, so that part of the BMS works as advertised.
Also, it takes a few seconds for the alternator to start charging after engine start, which explains the change in engine noise when cold. I've also discovered that the weird clicking noise with the engine off is the BMS measuring the charge state of the battery, as the voltage drops when this happens. But I'm still unsure why the instantaneous fuel consumption drops when waiting at the lights. I can't see how it can be the BMS as there's no change in voltage, unless there is a load shedding process that somehow keeps the voltage the same. Sent from my SM-G9208 using Tapatalk
#27 | ||
Last time I enquired at Battery World they didn't have a Yu-Fit device:
http://www.centurybatteries.com.au/resources/yu-fit but since then they have aquired one. I was told Yu-Fit is for idle stop start systems only and the Mondeo did not require a BMS reset when the battery is renewed. Meanwhile Forscan tells me the battery I changed about a year ago is about 6 years old (2200 odd days), which is the age of the car. On the trip today the zetec's charging voltage suddenly started going up and down as previously noticed, downhill 14.8, uphill 14.4, whereas for the previous 60km it remained steady at various voltages from 14.8 to 14.4. It takes a few seconds after starting engine for volts to go up as per NZ XR6. Last edited by rondeo; 28-04-2017 at 01:57 PM. Reason: addition |
#28 | ||
#29 | |||
Sorry. The administrator has banned your IP address. To contact the administrator click here
#30 | |||
Here's the youtube video embedded in the Taurus forum post: https://youtu.be/FAJeDX-T-Eg |
