Looking for recommendations for a 12v car battery charger that is suitable for use on a couple of garaged cars that are not regularly used.
I'm still alive
Ctek or Ozcharge. I've got an ozcharge and its fantastic. Not the cheapest available but i little cheaper than Ctek.
And if you believe the salesman apparently the bloke that owns Ozcharge was heavily involved with Ctek before starting his own company. Take that with a grain of salt though. Great charger though, lots of charging modes as well as maintenance and rejuvenation. Sent from my SM-G950F using Tapatalk
2006 BF XR6 Winter White Visual -Lowered on SSSL's -5000k Headlight conversion -DJR Bobtail -Darkest legal tint -Tinted taillights Audio -Ford Premium Sound -Pioneer 1000W 12'' Sub -Pioneer Class D Digital 800W Amp Performance -Custom Cold Air Intake Build Thread http://fordforums.com.au/showthread.php?t=11344773 |
Ctek.
![]() Join Date: Oct 2006
I've been using a cheap and cheerful Projecta one like this on a garaged car for years without an issue http://www.ebay.com.au/itm/PROJECTA-...sAAOSwuxFYxchd
regards Blue |
Call me dirt... Joe Dirt
C-tek.
I've got three of them.
2007 BFII FPV Cobra Ute|Boss 302|6M|#23/100 Mods so far: Billet Products Shifter|X-Force Exhaust|Herrod Oil Breathers|Whiteline Sway Bar|Tein SuperStreets|Kings FOR-303SL Rear Springs|Melling Oil Pump|Mace Manifold Spacers|Powerbond Underdrives|Pacemaker Headers|Ballistic Cats|XFT Custom Tune @ 308.3rwkw|DBA T3 Rotors|Ferodo Pads|Goodridge Braided Lines Mods to come: 4.11 Diff Gears|Chromoly Tailshaft I use & recommend: Castrol|Motorcraft|Mainlube|Penrite Check Out My Build Thread |
Never had a drama with the cheap and cheerful SCA charger I bought about five years ago.
Controlled by a microprocessor, does all common types of batteries up to 9 amps and there's not a battery it hasn't brought back to life yet. Sent from my iPhone using Tapatalk
ED Work-in-Progress Poly Green Sprint Bodykit Sprint 16's Ghia Interior AUIII XR8 Windsor T-56 6 sp 3.7:1's 258.6 rwhp |
It's not an FG MKI.......
Another vote for C-tek.
06/08 Manual FG XR6T. Not an FG1 or MKI, an FG... ![]() Want to know how to do an A Service for an FG XR6T? Look in this http://fordforums.com.au/showthread.php?t=11339404 Thinking of oil sampling your engine? Have a look at this trend http://fordforums.com.au/showthread....ght=oil+sample |
HSV - I just ate one!
Ctek make great chargers, Durst are good too but IMO more expensive and not so easy to find
#10 | |||
BA/F6 BF/F6 SSV/R TTG
Work perfect.
BA BF FPV starter button repairs. PM me. Nizpro equipped and Tuned by the BEST in the west Xtreme Ford Tuning 479RwKw Fuel limited, more pumps and power too come. F6#0507 & #0639 Pro racer and Tech expert NIZPRO modifying falcons like Premcar can only dream of , see VIDEO below. https://youtu.be/oa4IfguGQ-A |
![]() ![]() Join Date: Jan 2014
Had no issue with the Projecta one I've had for years.
2 users like this post: |
#12 | ||
Another one here for Ctek
2017 Mustang GT (Magnetic) |
#13 | |||
Performance Inc.
I have an Ctek 5A on the Lotus and a cheaper SCA sourced 3.8A one on the FPV no real difference in what they do you could buy @3 x SCA units for the price of the Ctek.
In The Garage... ![]() FPV Super Pursuit Build no 0080/91 Lotus Exige S/C S240 Kart Hasse Chassis 100J Power Quote:
#14 | ||
Experienced Member
I have a couple of these chargers, small, compact, cheap & very reliable that will give the big brand name chargers a run for for their money.
http://www.radioparts.com.au/product...e#.WS_ZqtwlHIU Cheers. |
#15 | ||
EL XR6
Another c-tek user
Winter white 15' FG X XR8 Shockworks coilovers | 1000cc injectors | DiFillipo Twin 3" exhaust | Bluepower tuned | 380rwkw Navy 97' EL XR8 Factory manual | Tickford kit | Pacemakers + Full exhaust |
#16 | ||
That radio parts charger looks very similiar to a Supercheap 2.5 amp charger.Only difference appears to be price.RP $65 SCA $52
#17 | ||
Thanks guys...very informative.
#18 | ||
I'm still alive
These are the Ozcharge's i was talking about. Seriously worth considering
![]() Sent from my SM-G950F using Tapatalk
#19 | ||
What does the rejuvenator part do, from a technical perspective?
I charge my batteries off a solar panel and charge controller but I'd consider getting a proper charger if rejuvenating is a real thing. |
#20 | ||
Op only wants a maintenance charger to give cars s float charge
If you want an all round charger use one of these. 25A and fully adjustable for amps and battery type
#21 | ||
Me too.
I've been running them for years on the farm, keeping maintenance charges in anything from boats to harvesters. Them trick with maintenance charges is getting the amperage low enough so you don't kill the battery. All maintenance chargers should be less than 1 amp. Most off the shelf battery chargers cannot do this unless they are very good.(expensive)
www.bseries.com.au/mercurybullet 2016 Falcon XR8. Powered by the legend that is - David Winter. XC Cobra #181. 1985 Mack Superliner, CAT 3408, 24 speed Allison. |
#22 | |||
Low amp 'trickle charging' is much better and prolongs battery life. |
#23 | ||
I'd agree with the above on NOT needing a high powered charger for maintenance charging.
A car battery is probably around 50 amp hours capacity and would be unlikely to lose more than 1 amp hour per WEEK of energy content just sitting in the garage doing nothing, so even 900 milliamps per hour is WAY more than is needed. Could probably use a 900 milliamp charger to keep two vehicles topped up in parallel - just add a second lead to the charger, or charge on vehicle for a week, then the other. Once charged the charger turns itself off anyway |
#24 | ||
Not sure if its a myth or not but we used to get told at my old workshop that leaving any type of auto battery on a concrete floor will discharge it.
Can't see how that is possible really? |
#25 | ||
Yeah I've heard that myself don't know how true it is but I don't take any chances and put something under my batteries anyway. As far as battery chargers go i have a PC400 Projecta and a Matson charger 1 on each car and both have done the job with no hassels both cars start every time when needed.
#26 | ||
Performance moderator
![]() Join Date: Feb 2005
Need atleast a 3 stage charger . 5 or 7 is best . The higher the amperage the more critical it so or over charging is easy done . To rejuvenate an old flat battery you need to charge it slowly . Hell owning a motorhome with 350 AH you go through batteries if you dont look after them . Have two types of charger . One in 40 amp to maintain batteries under load , starting etc if low charge . A 3 amp 3 stage Protecta charger to keep truck batteries charged .!
#27 | ||
#28 | ||
My projecta charger has battery rejuvinate function on it not sure if it works as i havent flattened a battery enough to need it
#29 | ||
Solar is FINE with good regulator., Same with charger .
#30 | ||
If you are considering getting a CTEK battery charger, now might be a good time to get one as there is a 20% discount offer on ebay up to the 11th June.
See here: https://www.ebay.com.au/sch/m.html?_...harger&_sop=16 |
