14-07-2017, 09:33 AM | #1 | ||
irregular member
Photos in the article.
http://www.drive.com.au/motor-news/h...12-gx9jcp.html South Korean brand whips the covers off its Volkswagen Golf GTI rival Hyundai has turned up the heat in the hot hatch segment with its first dedicated performance car. The South Korean car maker has revealed official details of its highly-anticipated i30 N, confirming the front-drive pocket rocket will be soldin Europe as two distinct models both of which generate more power than the Volkswagen Golf GTI it is benchmarked against. Due to arrive in Australian showrooms in November, Hyundai Australia has yet to determine whether it will offer the standard i30 N alongside the upgraded Performance Pack variant that will set the tone for the brand's first attempt at a vehicle designed primarily for driving enthusiasts. It has also not revealed where it will be positioned among its competitors in terms of price, but Hyundai has indicated it is aiming to at least match the basic Golf GTI's $41,490 (plus on-roads) sticker for the fully-loaded i30 N Performance Pack with the standard model coming in at around $37,500 if it decides to offer both. As the first images showcase, the hot hatch wears a host of unique design elements to give it a more muscular appearance than the cooking-version i30 hatch models, including a more aggressive front bumper with large air intakes crowned by LED driving lights on each side and a front splitter with a signature red highlight that protrudes from the lower edge to improve downforce at speeds. The outer edges of the bumper have been hollowed to create 'air fences' that direct air into the wheel arches to reduce turbulence and improve brake cooling. The rear-end also features a new bumper with a race-style diffuser with a twin-exhaust system and a unique rear wing mounted on top of the hatch with a triangular stop light. Both models are powered by a 2.0-litre turbo charged four-cylinder engine that drives the front wheels through a six-speed manual transmission, which will be the only gearbox offered initially but it is known that Hyundai is working on a seven-speed dual-clutch unit. In the standard version it pumps out 184kW at 6000rpm and 353Nm of torque between 1450-4000rpm and powers through a conventional front differential with the ability to sprint from 0-100km/h in 6.4 seconds. The Performance Pack increases the duration of maximum boost pressure to extend its maximum torque figure to 4700rpm, which improves its power to 202kW. It has an electro-mechanical limited slip diff and a shorter final drive ratio which contribute to lowering its 0-100km/h time to 6.1 seconds. Apart from those extras, the Performance Pack also picks up a bi-modal exhaust system as well as more supportive front seats, higher-grade interior trim with leather and suede throughout the cabin and a larger 8.0-inch colour touch screen multi media system with Bluetooth, digital radio, sat nav, smartphone mirroring and specific N performance pages that allows the driver to customise the settings for individual parameters of the car as well as monitor the engine's outputs while on the fly. Those behind the wheel can quickly toggle through multiple driving modes - Eco, Normal and Sport - using the paddle under the left-hand steering wheel spoke or instant access to the track-focused N mode on the other side. Drivers can also tailor the engine's responsiveness, the amount of clamping on the differential, the stiffness of the suspension, the weight of the steering, the amount of intervention from the electronic stability control and the degree of assistance offered from the rev-matching system within the transmission. Being a true driver's car, the ESC can be fully de-activated as can the rev-matching function with its own button on the steering wheel. Both variants feature a totally unique MacPherson front strut and multi-link rear suspension set-up with adaptive dampers and an exclusive electric power steering system with the motor mounted directly to the rack for more precise feedback through the wheel. However, the standard car has 18-inch alloys wrapped in Michelin rubber where the Performance Pack has larger 19-inch alloys fitted with Pirelli P-Zero tyres developed exclusively for the i30 N. The i30 N hatch will be the first in a range of high-performance products developed by a team led by former BMW M boss, Albert Biermann, with the sub-brand expected to develop go-fast versions of the upcoming Kona small SUV, the swoopier i30 Fastback and the next-generation Veloster coupe. "With the high-performance N models we will enhance our brand's appeal with emotional products that cater to the needs of people who love to have a smile on their face when they drive their car on a winding road and listen to the sound of the engine," he said. "That's why we measure high-performance in BPM, heart beats per minute instead of only RPM." Last edited by Sioso; 14-07-2017 at 09:41 AM. |
12 users like this post: |
14-07-2017, 01:26 PM | #2 | ||
Render unto Caesar
Doesn't look too bad.
"Aliens might be surprised to learn that in a cosmos with limitless starlight, humans kill for energy sources buried in sand." - Neil deGrasse Tyson |
16 users like this post: |
14-07-2017, 01:36 PM | #3 | ||
How creative. The former BMW M boss comes to Hyundai and decides to call their performance division 'N'
14-07-2017, 01:44 PM | #4 | ||
Workshop & Performance
They've done a nice job for a first 'real' effort. Bit more sedate looking than expected. Great interior though. But where's that unsubstantiated 'Ring record to get some free coverage...oops sorry wrong company!
When close is good enough and the 6 MPS in the driveway has FoMoCo written all over the place. Xr5 for sale shortly...just not a hatch guy |
14-07-2017, 02:09 PM | #6 | ||
Motorsport Guru
Could it be the 'N' derives from Michel Nandan, Team Principal of Hyundai Motorsports?
Interior Enhancements: Footwell Lighting, Brushed Alum. H/brake Handle, 6 Disc In-Dash System. Exterior Enhancements: ST170 Wheels, Richbrook Shorty Aerial, Euro-Spec Hatch Handle. Performance Enhancements: Ate Callipers/EBC Rotors/EBC Greens Stuff Pads, ST170 Suspension, Herrod's Custom Tune, Ford Racing Coated Exhaust Manifold & Bespoke 2.25in Exhaust. Awards: AFD '07 EFOC Best Focus, SFS '09 EFOC Best Focus, SFS '10 RSOC O/all Best Focus, AFD '10 CFC O/all Best Focus. |
14-07-2017, 02:13 PM | #7 | ||||
Render unto Caesar
14-07-2017, 03:03 PM | #8 | ||
irregular member
14-07-2017, 03:18 PM | #9 | ||
Peter Car
I call him baby blue. Where's golden boy?
Terrible colour. |
14-07-2017, 03:37 PM | #10 | ||
Clevo Mafia Inc.
I like it, should fill it's niche quite well.
14-07-2017, 04:35 PM | #12 | ||
Looks like the bastard child of a GTi, RS and a Golf R. Not implying thats a bad thing, in another colour it'd look rather good. 10x better than the new Type R, a little restraint can go a long way. The rear design's a little busy that's all i'd say, but from all other angles quite sweet. Be interesting to see price positioning, UK estimates above ST and below GTi. Certainly sounds the goods too, but wonder if that sound will travel here, or anywhere for that matter from the prototype.
14-07-2017, 05:25 PM | #13 | ||
It looks pretty decent in my opinion given it's their first real crack at this segment. Think back to when the Excel came out and they are miles away from that.
I'd probably use a better choice of colour to promote it |
14-07-2017, 11:25 PM | #14 | |||
This thing though, I love the look of it, nice interior and bloody good value.. be interesting to see the first Aussie Road Test but either way, well don't Hyundai...
2008 FG XR6 Turbo ZF In Sensation - Gone, but not Forgotten.... Hers: 2024 Ford Everest Platinum in Equinox Bronze His Daily: 2020 (MY21) Kia Sorento GT-Line in Mineral Blue His Weekender: 2017 Commodore SSV Redline manual in Light My Fire Orange |
15-07-2017, 09:21 AM | #15 | ||
It's a step up from the Veloster Turbo (which was pretty much the same engine setup as the Kia Pro C'eed GT) ... unfortunately both didn't sell too well back then ... and the Kia was dropped from the market due to lack of sales anyway.
Will be interesting to see how well this one goes against the current market.
15-07-2017, 09:55 AM | #16 | |||
"N stands for 'Namyang', the name of the place where Hyundai Motor’s global R&D center is located." http://brand.hyundai.com/en/n/about-n/about-n.do |
15-07-2017, 12:44 PM | #18 | |||
Former BTIKD
https://www.uniquecarsandparts.com.a...specifications
7 users like this post: |
15-07-2017, 12:49 PM | #19 | |||
Rolling acceleration is where this car will shine. |
3 users like this post: |
15-07-2017, 02:20 PM | #20 | |||
Fgx xr8 winter white manual, gone but not forgotten 22 mitsubishi outlander XLS PHEV Au11 fairmont Ghia ported gt40p heads ,comp springs and locks Xe 264 cam,custom intake,pacemaker tri y headers 524nm torque 19 Triton GSXR manual |
15-07-2017, 09:12 PM | #21 | ||
Clevo Mafia Inc.
I was browsing the Hyundai dealer today, picked up a new MY17 i30 SR manual for the wife, after a spirited test drive up the Dandenongs I think I may borrow it often. They are a lot of car for the price.
The i30N with an extra 34kw would be LOT of fun. |
4 users like this post: |
16-07-2017, 09:04 PM | #23 | ||
GT4.
9 users like this post: |
17-07-2017, 09:10 AM | #24 | ||
Get in the ring!!!
I test drove an i30 SR auto last week, very impressive piece of kit. What did you get the manual for if you don't mind me asking? My Mother in law has the Elantra SR Turbo Auto and loves it. I think the N will be a great car, it will have to be with the competition it has.
FG MKII XR6T - Tuned by Pit Lane |
17-07-2017, 09:39 AM | #25 | ||
17-07-2017, 10:30 AM | #26 | ||
To be fair you have compared some sort of grandma wagon, a GTI hatch would be closer, but yes quite different
______________________________ 2015 Territory Titanium RWD Diesel - SOLD 2016 BMW X5 xdrive 30D Msport Seadoo Challenger 210SE 310HP |
17-07-2017, 12:59 PM | #27 | ||
Looks good, more Audi A3 like for my mind (and nothing like a Golf wagon).
I'd consider if was looking at hatches. |
17-07-2017, 01:39 PM | #28 | |||
Clevo Mafia Inc.
17-07-2017, 03:08 PM | #29 | ||
Peter Car
17-07-2017, 07:45 PM | #30 | ||
G'day ..Not my cup of tea but it is a big step up for hatches at a good price, that's for sure..Cheers Rod..
