Old 13-04-2018, 08:13 AM   #1
Garyvpein1991
Default Ba bf injectors on fg?
G'day fellas I bought some 1000cc injectors for my na fg xr6 that I am going to be boosting, and was told they are for fg but are actually ba bf injectors, is it possible to make them fit?? Also do they need adaptors? Not sure on these as this I the first car I will be modifying , always had standard cars
Garyvpein1991 is offline   Reply With Quote Multi-Quote with this Post
Old 13-04-2018, 10:03 AM   #2
NTF6
Default Re: Ba bf injectors on fg?
I thought it was the other way around, you can use FG injectors in BA/BF with spacers as the BA/BF injector is a full length injector and FG is a 3/4 length, so if I'm right you won't be able to use them in your FG.
2017 Mustang GT (Magnetic)
NTF6 is offline   Reply With Quote Multi-Quote with this Post
Old 13-04-2018, 10:06 AM   #3
Mont5.0
Mont5.0's Avatar
How much boost you planning on running?
FGII XR6 IN LIGHTNING STRIKE
R52 SIII IN GUN METALLIC
Mont5.0 is offline   Reply With Quote Multi-Quote with this Post
Old 13-04-2018, 02:17 PM   #4
Garyvpein1991
Yeah I was told that but then someone said to me that you can space the fuel rail about 17mm or so and use them?? I'm going to start at around 14psi but later on I'll get some stronger parts for my engine and increase the boost
