Old 31-05-2018, 11:40 PM   #1
wood spirit
Unhappy Totaly dead battery -how to get in???
Yeah tis a camry(2002/3) - but presume the problem is the same. Will not open even with the key. can access boot -but the seats release is on the inside.
No doors open -can't climb through the boot, doubt I can access bonnet release
open to all suggestions. -preferably without smashing glass.
wood spirit is offline   Reply With Quote Multi-Quote with this Post
Old 31-05-2018, 11:50 PM   #2
Default Re: Totaly dead battery -how to get in???
If you get under the car, can you access the power cable bolted to the starter?
If so attach a charger to it and then attach earth to anyplace on the chassis. Let it sit for a while before attempting to start.
7 users like this post:
Old 31-05-2018, 11:52 PM   #3
Hook a jumper pack or jumper cables to the body and positive of the starter motor. Then try the remote If its accessible from underneath on jack stands. Safety first.
.:4:. is offline   Reply With Quote Multi-Quote with this Post
Old 01-06-2018, 08:27 AM   #4
GT450
Join the local motoring club...NRMA RACQ RACV?? and they will open it. Probably better than paying for glass replacement and you have a years assistance.
GT450
GT450 is offline   Reply With Quote Multi-Quote with this Post
Old 01-06-2018, 10:17 AM   #5
Vesper Martini
Vesper Martini's Avatar
I would have thought the key would manually open the door on an 03 Camry?
______________________________
2015 Territory Titanium RWD Diesel - SOLD
2016 BMW X5 xdrive 30D Msport
Seadoo Challenger 210SE 310HP
Vesper Martini is offline   Reply With Quote Multi-Quote with this Post
Old 01-06-2018, 09:28 PM   #6
foxtrot3
foxtrot3's Avatar
Hi. One would hope so, BUT after fifteen years of using a remote to unlock the doors this toyota like many I see will have the key barrels in the door handles seized. A good spray with CRC/WD40 etc etc etc may bring them back to life and you may find that the drivers door will only lock the car while the passengers door will only unlock the car. Cheers MD
HI
I'M MICHAEL
foxtrot3 is offline   Reply With Quote Multi-Quote with this Post
Old 01-06-2018, 11:37 PM   #7
Crazy Dazz
WD40 and a bit of hand strength should get the key turning.
Ask one of your grandkids to lend a hand
Old 01-06-2018, 11:51 PM   #8
Careful of snapping the key.
It can happen.
Old 02-06-2018, 06:48 PM   #9
whitelion65
whitelion65's Avatar
It can happen.
Yep, use a spare, or get one cut.
Steve
Current rides
2012 Mondeo Titanium wagon (TDCI)
Moondust silver
2016 Focus Trend, 1.5ecoboost, 6sp manual.
Frozen white
Previous
2004 Berlina Wagon (LS1) Vespers Blue
1995 Camry 2.2, white
1971 Ford Fairmont wagon 302w, C4 Polar white
1971 TC Cortina, 2L 4sp, Ermine white
whitelion65 is offline   Reply With Quote Multi-Quote with this Post
Old 03-06-2018, 12:15 AM   #10
wodahs
wodahs's Avatar
true n tried age old method
youll need a brick
yes still (as money n time permit) doing the
rebuilding the zh fairlane with a clevo 400m 4v heads injected whipple blown with aode 4 speed trans to a 9" ....... we'll get there eventually
just remember don't be afraid to try something new.
Remember, amateurs built the Ark...Professionals built the Titanic!
I have taken up meditation... at least it's better than sitting around doing nothing !!
wodahs is offline   Reply With Quote Multi-Quote with this Post
Old 06-06-2018, 07:12 PM   #11
ebzery
had to get into a ba falcon like this was lucky it had some wiring i could hook into i think i used the park light and feed back to the dash worked a treat.
sorry number plate light i meant
ebzery is offline   Reply With Quote Multi-Quote with this Post
Old 06-06-2018, 09:19 PM   #12
barrys123
barrys123's Avatar
I don't think that will work as you won't have a circuit from number plate light unless the lights are turned on.
barrys123 is offline   Reply With Quote Multi-Quote with this Post
Old 07-06-2018, 11:17 AM   #13
Vesper Martini
It can happen.
actually I think its the same key as our 04 Prado. they snap real easy
Old 07-06-2018, 11:20 AM   #14
Ooops !
Be very careful then.
Old 07-06-2018, 11:29 AM   #15
I wonder if Wood Spirit ever got in...
Old 07-06-2018, 08:34 PM   #16
ebzery
you dont need to power the hole car just the remote central locking!
Old 06-06-2019, 10:57 PM   #17
wood spirit
Actually with the camry -broke off the plastic cover for the bonnet catch -opened such with a screwdriver and charged battery. all good from there -only very minor damage done.
Old 06-06-2019, 11:04 PM   #18
pottery beige
woo hoo
Old 07-06-2019, 09:45 AM   #19
mike_nofx
mike_nofx's Avatar
How to double the value of an 02 Camry? Replace the battery.
mike_nofx is offline   Reply With Quote Multi-Quote with this Post
Old 07-06-2019, 09:58 AM   #20
Electrolyte Burns
One would have to wonder how stupid you would have to be to design a car in this way.
They must live on another planet to the rest of us.
Electrolyte Burns is offline   Reply With Quote Multi-Quote with this Post
Old 07-06-2019, 10:00 AM   #21
Vesper Martini
You couldn't open the door with the key and pull the bonnet catch lever?
Old 07-06-2019, 11:20 AM   #22
ebv8
ebv8's Avatar
I locked my AU and then disconnected the battery and closed the bonnet, realised the key didn't open the drivers door
so i jacked it up and got under it and "reached around" and while pressing the central locking button and tapping the battery cables i got it open, i disconnected both cables so it was PITA but i got in
also jumper leads to ground and starter or alternator positive should get it powered up
note to self: if i disconnect the battery again i'll leave the bonnet ajar and/or door unlocked
CURRENT RIDES
BA GT Mk1 #0009 - Narooma Blue
SY Ghia AWD
Black VZ LX8 Adventra
Holden HX 50th Anniversary
AU Saloon Car racecar
1980 GS1000ST - Wes Cooley Rep
ebv8 is offline   Reply With Quote Multi-Quote with this Post
Old 07-06-2019, 11:25 AM   #23
94_ef
This is why you should leave your kids in the car.
2014 Ford Ranger XLS 3.2L 4x4 Dual Cab.
2003 Ford BA Fairmont Ghia sedan.
1994 Ford EF Fairmont Ghia sedan.
1994 Ford ED Falcon GLi wagon. Discovered my love for Ford 4L.
94_ef is offline   Reply With Quote Multi-Quote with this Post
Old 07-06-2019, 11:37 AM   #24
snap0964
Take the door lock barrel out and get it matched to the key - then you have no worries about forgetting the other things, otherwise, it will bite you on the a*se again - I'm talking from experience .
snap0964 is offline   Reply With Quote Multi-Quote with this Post
Old 07-06-2019, 07:40 PM   #25
MITCHAY
Probably but does it disarm the alarm? I can unlock my WRX but then the alarm goes off.
I can turn that off with a key in the engine bay after getting a nice blast but pretty sure I can't start the car anyway
Old 08-06-2019, 12:52 AM   #26
XR Martin
XR Martin's Avatar
Sounds like someone replaced the ignition barrel at some stage but didn't think it would ever be necessary to match the door lock, or at least keep a key.
2004 BA wagon RTV project.
Old 08-06-2019, 07:59 AM   #27
I see what you did there.
Old 08-06-2019, 08:03 AM   #28
A visit to your local locksmith will solve your problem.
Old 10-06-2019, 12:26 AM   #29
janddbone
B1 - J & D Services
janddbone's Avatar
When Ford used those Tibbe locks, Ea to AU, every single Tibbe key would lock the door, but only the right one would unlock it. I got reminded of this just the other month when I learnt my AU does not have matching door and ignition locks anymore!
Mr. Brett Johnstone.
2002 Ford Laser
2000 Ford Falcon Wagon Egas
1999 Subaru Imprezza Sportwagon
1998 Holden Suburban 2500
1995 Land Rover Discovery TDI
1994 XG XR6 Longreach
1983 Holden Rodeo
1975 Datsun 120Y wagon
1970 MG Midget
1967 Rover 2000TC
Soon: Model T.
janddbone is offline   Reply With Quote Multi-Quote with this Post
Old 11-06-2019, 09:28 AM   #30
Vesper Martini
True for some cars but still better than breaking trims to get into the car I would have thought..
I don't think an 03 Camry has an audible alarm, you can enter/start our Prado just by using the key.
