Old 27-09-2018, 10:05 PM   #1
Tonz
Default dash cluster needles
how would I go about changing the dash cluster needles to white from red?
Dont p i s s off older people. At our age the term Life in Prison is not a deterrent
Tonz is offline   Reply With Quote Multi-Quote with this Post
Old 27-09-2018, 10:10 PM   #2
Default Re: dash cluster needles
Have you thought about simply painting them.
Old 28-09-2018, 08:31 AM   #3
Tonz
Well no, but they light up at night time...or they appear to...where does that light come from.
just toying with an idea of dash clusters background black, numbers blue and needles white...
Old 28-09-2018, 04:29 PM   #4
roKWiz
Cabover nut
roKWiz's Avatar
Luminescence paint maybe.
heritagestonemason.com/Fordlouisvillerestoration
In order that the labour of centuries past may not be in vain during the centuries to come...... D. Diderot 1752
roKWiz is offline   Reply With Quote Multi-Quote with this Post
Old 28-09-2018, 04:43 PM   #5
Interceptor
HSV - I just ate one!
Interceptor's Avatar
Model paint and an airbrush so you don't lay it on thick, there are model paints available that are effectively a tint that will be perfect for this
I dont care if some prius driving eco-hippy thinks its politically incorrect for me to drive a V8..... I'm paying for the fuel!
Interceptor is offline   Reply With Quote Multi-Quote with this Post
Old 28-09-2018, 04:47 PM   #6
raceteam
Perhaps saying what vehicle would be helpful. Some are clear needles lit by coloured light from the back.
raceteam is offline   Reply With Quote Multi-Quote with this Post
Old 28-09-2018, 04:58 PM   #7
MITCHAY
I don't know what car you have or if you need to do it but I once decided to change the back lighting on my dash which meant you needed to sand the green film off the back of the dials. It seemed simple enough at the time but turned out to be a disaster.
I'd reconsider doing this if it is the case because I ended up accidentally popping off the needles and then needing a 2nd hand cluster (luckily one with similar kays give or take about 100kms) as it just could not reset the needles. Very expensive lesson.
Old 28-09-2018, 05:00 PM   #8
Tonz
sorry folks fg2 ute
