28-02-2019, 11:30 AM | #1 | ||
Hi
Is it possible to get one of those wavlink like this https://www.ebay.com.au/i/2925752210...32bf90ffe04d25 And put this on roof and run a ethernet cable in to the rv and plug it into a router in the rv and pick up the parks wifi just like you can with the proper rv-wifi (https://www.rvwifi.com.au) If you get a router that will work with a 3g and 4g modem can you also mount a antenna for that on the rv and also pick up 3/4g too like the rv wifi you can buy that’s designed for a rv |
28-02-2019, 12:42 PM | #2 | ||
Cabover nut
Yes you can.
28-02-2019, 01:39 PM | #3 | ||
Ok thanks thought it would but wasn’t sure and the wavlink in link will pick up the eb parks wifi and send it in your own rv if you plug the wavlink in to the wan port is that right
02-03-2019, 09:36 AM | #4 | ||
If you do following will it do same job as a rv-wifi setup
Put the wavlink repeater outside Plug it into router inside by data cable Put a 3/4g modem inside next to router and plug in by usb or data cable Then you re-transmit wifi and have 3/4g internet |
04-03-2019, 10:07 PM | #5 | |||
Bolt Nerd
I brought that same Wavlink extender from Jaycar on last trip back to Aus. Have it setup to enable WiFi down to pool area (about 200m away) Interestingly, I was at neighbours place a kilometre away the other day and was still able to log into my Wavlink. So their range is pretty impressive! Sent from my iPhone using Tapatalk
Current vehicles.. Yamaha Rhino UTV, SWB 4L TJ Jeep, and boring Lhd RAV4 Bionic BF F6... UPDATE: Replaced by Shiro White 370z 7A Roadster. SOLD Workhack: FG Silhouette XR50 Turbo ute (11.63@127.44mph) SOLD 2 wheels.. 2015 103ci HD Wideglide.. SOLD SOLD THE LOT, Voted with our feet and relocated to COSTA RICA for some Pura Vida! (Ex Blood Orange #023 FPV Pursuit owner : ) |
04-03-2019, 10:49 PM | #6 | |||
If you were to buy a wavlink to receive wifi then plug it into a router then re transmit wifi in your rv will that do same job as proper rv wifi wether or not you buy a 3/4g modem too |
04-03-2019, 11:33 PM | #7 | ||
Bolt Nerd
Below is the link.. I have mine conected to indoor router with LAN cable, and supplied PoE transformer needs power (120v in our case)
https://www.wavlink.com/en_us/product/WL-WN570HA1.html
05-03-2019, 12:11 AM | #8 | |||
05-03-2019, 12:25 AM | #9 | ||
Bolt Nerd
Yes, No problem!
