Old 20-10-2019, 06:38 PM   #1
Sprintey
Sprintey's Avatar
Default 80,000 dual clutch gearboxes recalled
Not Ford this time:
https://www.caradvice.com.au/800297/...-in-six-years/
Some of the poor owners tell their story in the comments section.
I6 + AWD
Sprintey is offline   Reply With Quote Multi-Quote with this Post
Old 20-10-2019, 06:54 PM   #2
Yellow_Festiva
Where to next??
Yellow_Festiva's Avatar
Default Re: 80,000 dual clutch gearboxes recalled
How the hell did these gearboxes pass testing during the development stage?
How could companies like Ford, VW and Audi etc think they could sell millions of these faulty units and get away with it?
___________________________
Old 20-10-2019, 09:03 PM   #3
jpd80
jpd80's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Thoughtful contributions to our community
If you've been following the story at Ford, they actually didn't pass, the engineer overseeing
development had grave reservations about shift quality and said that the box needed more
development time. The alarm bells should have been going off back then.
But the biggest rasberry should go to Getrag, they must have known that this box was a
crap box of problems waiting to happen. Ford and GM should be back charging them heaps.
Sad fact is that the Ford-GM torque converter 6-speed automatic would have worked perfectly,
Ford USA had it there but couldn't convince Ford Europe to change their design and use it.
And when they finally did in 2015, Ford NA was too cheap to switch away from 2.0 DI
as nearly every Focus they made lost money. Go figure Ford doing this to itself to save money.
jpd80 is offline   Reply With Quote Multi-Quote with this Post
Old 20-10-2019, 09:32 PM   #4
GTLEGEND
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Every advice post I visit where OP are seeking advice for their new vehicle, he is there and adds valuable support and advice for rectifying the problem. Really is a Legend. Technical Contributor: For members who share their technical expertise. - Issue reason: The quality of information he provides is in depth and highly valued by those posting questions.
I would rather think that during development stage the prototype parts worked well for the issue VW are having. Most like that when the parts are then mass produced by the supplier, anything could happen and you get issues like this. Proto parts are usually well made, sometimes hand made and become not so good when mass produced or suppliers take short cuts with cheaper materials etc unbeknown to the vehicle manufacturer.
GTLEGEND is offline   Reply With Quote Multi-Quote with this Post
Old 22-10-2019, 02:29 AM   #5
happy1
Originally Posted by GTLEGEND View Post
I would rather think that during development stage the prototype parts worked well for the issue VW are having. Most like that when the parts are then mass produced by the supplier, anything could happen and you get issues like this. Proto parts are usually well made, sometimes hand made...
That's exactly it, and even further than that! One of the engineers I know within the automotive industry in Europe that used to be working with automated clutches on manual transmissions (not the DSG provider to VW) told me a story about how they always prepared test vehicles with tighter tolerances than factory spec. For example all drive shafts, differentials, transmissions etc. on a brand new test vehicle always got 'rebuilt' or prepared with tighter tolerances (far less backlash) than how it came from the assembly line for the mass produced vehicle. So the supplier industry is actually cheating when hand-building their R&D valuation vehicles that the car manufacturer's representatives will test-drive and sign off. After preparation these vehicles were only 'excellent' for a very limited range of usage..
happy1 is offline   Reply With Quote Multi-Quote with this Post
Old 22-10-2019, 12:08 PM   #6
guzzis3
AU3 ute EL futura
guzzis3's Avatar
Those VW gearboxes have been rubbish from the start.
15 years ago a workmate's daughter bought a VW 4b, the big one forget the stupid name. It never went from new and after a dozen trips back to the dealer on a tow truck she just gave up and parked it in her front yard.
My ex's mother had a golf what ? 12 years ago. By 130k kms they sold it for scrap. Started breaking down at 70k. It's well known the trans only last 130k then need about a $7k rebuild. Incredibly she bought another one which started breaking down in the first few thousand k's. They have nice seats lovely interiors and the diesel has a ton of grunt but as soon as you fire it up they start annoying and disappointing you. The throttle and brakes in the new ones are lethal and I refuse to drive it. Total POS.
The Stuttgart porsches are the only european car worth buying. The Macans use the VW box and motor and the cheyanne are pretty sus also. Everything else is garbage.
guzzis3 is offline   Reply With Quote Multi-Quote with this Post
Old 22-10-2019, 04:59 PM   #7
cheap
Wirlankarra yanama
cheap's Avatar
FWIW - my mates 2017 Macan has a failed transfer case and damaged driveshafts - a known issue it would seem. Nearly $10k to repair luckily under warranty.
cheap is offline   Reply With Quote Multi-Quote with this Post
Old 22-10-2019, 05:11 PM   #8
jpd80
jpd80's Avatar
And why it's getting so trap ridden to buy expensive used vehicles without a good warranty.
Old 22-10-2019, 06:14 PM   #9
guzzis3
AU3 ute EL futura
guzzis3's Avatar
That is why you buy ford. No one is surprised when it breaks down
Old 22-10-2019, 08:21 PM   #10
cat007
For the VW side of things, appears to be only AU Golf's? Got a brother in NZ with a mk6 GTI and apparently NZ new VW's are not affected?
Sent from my LYA-L09 using Tapatalk
cat007 is offline   Reply With Quote Multi-Quote with this Post
Old 23-10-2019, 01:47 PM   #11
Bossxr8
Peter Car
Bossxr8's Avatar
More like they haven't issued the recall yet. Or are ignoring the issue. There should be no difference between aus and nz cars.
