Was just about to buy some Morocraft but just saw these totally new 'Sniper' coils as my XRT is breaking down under load very badly all the time its actaully quite dangerous.
Tried Goss coils, No good. These snipers are around the same price as FoMoCo coils so i'm going to try them ASAP. https://www.ebay.com.au/itm/SNIPER-H...8AAOSwPcVVqfDE |
Japanese provenance is a good start. They’re what - $1 each dearer than genuine?
Who’s currently OEM for the latest version of BA-BF coils? Is it VDO, NGK, Delphi, Bosch? |
If you get them let us all know if they live up to the hype of the seller.
XC GS OLD SCHOOL MUSCLE ![]() Audi A4 S-line quttro Xc falcon Previous fords- xc falcon 500 ,250 x flow 3 speed xc gs worked 250 x flow 4 speed xa Fairmont 302 auto wagon xb falcon 250 log auto 4 door xb falcon 200 log auto ute xc gs project - had to sell :-( xc gs 302 4 speed 4 door xc gs 351 auto 4 door zf fairlane 302 auto zk fairlane 250 x flow carb auto zl fairlane 250 x flow EFI auto xg ute , BA falcon dedicated gas xd, xf x 3 ,ea,eb,ef,au x 3,telstar tx5 |
Still Visteon
I thought Visteon coil production had morphed into a part of Ford/Motorcraft, then been offshored to the usual place. Are they in fact still 85% American made?
Do the stock coils also do multi spark discharge? Trying to figure out how a coil swap alone, with no retuning or rewiring would achieve that unless it does it stock as well.
Thailand Specials
I've got the ACDelco LS2 'truck' coils on one of my cars, it's still sold as a 'genuine part' in the USA but it's a cheaper crappier coil than the factory spec Delphi coils.
Had one crap out in about 5000km, turns out they've got a 4% failure rate. Chinese special - surprise surprise. If you really want to go to a different coil the factory ignition coils on R35 GTR are very good items and have a lot of aftermarket support - there's probably a Barra kit in the works. Last edited by Franco Cozzo; 31-10-2019 at 01:06 PM. |
So, you’re implicitly saying Delphi coils are good gear?
Thailand Specials
2 users like this post: |
I dunno i'm trying these as the write up says they have 'aircraft' electronic parts and they can continue pumping out power while under big loads which i dont think stock coils or the coils can do???
Worth a try??? |
#12 | ||
They arrived yesterday afternoon so i fitted them in last night and went for test drive.......No more BACKFIRING under load/boost or stalling at lights and misifirng!!!!!!
Very happy.......for now. ![]() |
Update.....
Seems to feel like a little less power output but definately no more problems with popping/backfires etc. BPRD tune coming soon plus BF front brake rotor upgrade aswell.......Maybe depending on $$$$?? |
#14 | ||
Update........Sniper coils, NO GOOD after only about 2 weeks!!!!!!!!!!!
Was driving a bit 'erratically' yesterday afternoon and all of a sudden huuge backfires started under load then misfiring at idle. Have already refitted the old originals i kept so i can send the snipers back and get a refund so i can by FoMoCo coils. Freaking hope they work o.k??? |
#15 | ||
What a saga. Hope you find the OEM coils perform as expected.
#16 | ||
Maybe the coils are all fine and problem is something else?
3 users like this post: |
#17 | ||
Exactly what I was thinking too.
Current Rides: 2017 Ford Mustang 2020 Ford Everest Sport Past Rides: 2017 Kia Stinger GT 2008 FG XR6 Sedan 2008 FG G6E Sedan 2004 BA XR8 Sedan 2008 BF XR6 Turbo Sedan 2004 BA XR8 Sedan 2003 BA XR8 Ute 2003 BA XR6 Sedan |
#18 | ||
Not that it matters now, but I tried many sets of different snake oil type coils and at the peak of its eventual power and driveability I was running BF genuine coils from Ford.
Stay Genuine. |
#19 | ||
Why are you not using OEM coils? These have been proven to be very capable for a well over 400kw. How much power are you putting down?
#20 | |||
![]() AFAIK the only modsd i can see is slightly bigger turbo compressor housing (same stock size trubine tho) plus a slightly bigger new straight thru Cat fitted last week?? It was o.k for 2 weeks but not anymore.....was only running on asbout 3 or 4 cylinders yeasterday!!!!!! |
#21 | |||
![]() AFAIK the only mods i can see is slightly bigger turbo compressor housing (same stock size turbine tho) plus a slightly bigger new straight thru Cat fitted last week?? Oh and i fitted CAI when i first got it. It was o.k for 2 weeks but not anymore.....was only running on about 3 or 4 cylinders yesterday!!!!!! They're refunding in full so i'll order Genuines when that money comes back. |
#22 | ||
Update....
Got onto a set of cheap second hand Ford coils (i know theyre second hand) for $60. just threw them in and accelleration is much better but thers still some missing and hesitation 'sometimes'. I'm running 95 RON fuel with new fuel filter and new Ford Turbo plugs plus CAI. What else could be causing the hesitation??? |
#23 | ||
Stuffed ignition drivers in the ECU, possibly.
Cracked plugs, gasket issues, cracked head, bore damage, valvetrain faults. I'd suggest getting each coil pack input signal on a scope. |
#24 | ||
Just spoke to BPRD.
Possibly plug gap too big (gotta reset to .7mm) And, ziptie all the coil loom connectors together as my connector locks are all brittle and broken possibly causing faulty connection. Will do this tonight when its a bit cooler after dinner. |
#25 | ||
I think AFI or someone sell new connectors. Most release the pins from the back, so you can exchange the old housing with new.
#26 | ||
Blody plugs were huuge @ 1.00mm no wonder.....theboost pressure was obviously blowing the spark of the splug during firing stroke.
Re3st all to .7mm and also used a small amount of RTV sealant on each coil so the connectors would stay on after the sealant sets. Test drivinjg in HOT Melourne weather today it definately putting more power down but......I still does misfire .....sometimes??? |
#27 | |||
1mm is fine. 1.1mm is the stock gap. |
#28 | ||
No it ISNT Cat007 as i have just proven!!!!!!!
The boost pressure obviously blows the spark off the plug under high load. I just been driving quite hard before and damn it goes much better now... Def not stock this project car i really want to throw it on BPRD Dyno and find out if its been tuned already..... It goes very well and spools up quick as!!!!!!!!!!!!!! ![]() ![]() Last edited by GASWAGON; 22-11-2019 at 08:04 PM. |
#29 | |||
Peter Car
And the whole "blows the spark out under boost", when the boost level is stock is utterly ridiculous. It simply will not do that. You have other issues. |
#30 | |||
SO, obvoiulsy, more ****ing air is being pumped in than stock!!!!!!!!!!!! I ****ing told you .....' it aint stock'!!!!!!!!!!! Last edited by GasoLane; 24-11-2019 at 11:44 AM. Reason: Don't try to avoid the censor |
