Old 12-01-2020, 03:48 PM   #1
marcoseel
Default Au 1.5 Ute
Hi I have a Au Ute that the bcm smartsheild has locked it out from starting
I’m asking if I replace the bcm ecm and key reader and key to another set will it start as long it’s a series 1
I’ve tried a series 2 and it’s not the same the Ute is a manual
Thanks
marcoseel is offline   Reply With Quote Multi-Quote with this Post
Old 14-01-2020, 11:59 PM   #2
superroo
You can't stop the signal
superroo's Avatar
Default Re: Au 1.5 Ute
Needs to be 1.5 gear and the ECU is required as well.
Series 1 BEM won't work in a ute. I know from experience
Old 16-01-2020, 07:01 PM   #3
marcoseel
Ok thanks was hoping to do a pats reset with scan tool to fix that problem
Old 29-06-2021, 07:39 AM   #4
Nick001
Hi just wandering if you got this sorted.
Nick001 is offline   Reply With Quote Multi-Quote with this Post
Old 29-06-2021, 09:27 AM   #5
lumen8
lumen8's Avatar
If you cant find a ute 1.5 bcm/ecm and key/column gear , sedan and fairlane ones will work. If you use these bits from a dual airbag car it will throw a code for the missing airbag if your ute only has one, thats about the only fault ive noticed running a fairlane bcm and ecu in a ute.
lumen8 is offline   Reply With Quote Multi-Quote with this Post
