Or...... just fixes that tie you over till part arrives...
I cracked the rubber on a Ford Ranger engine mount... This held for over a week... ![]() ![]() And recently I cracked the mount on the plate that gear stick connects to... ![]() This is still in place. I currently have a faulty oil cooler (oil getting into coolant mix) and have bypassed the cooler... ![]() Still in place too... Any other takers? |
2 users like this post: |
Time to trade her in.
I once saw a HD Holden with half a house brick for an engine mount and all tied up with nylon rope.
jaydee351 4DV8 |
#3 | |||
T3/Sprint8
![]() Join Date: Jan 2005
Oh for the practical minds back in the day ![]() Saving the buck hasn't changed but how haha
I once fixed the accelerator cable that had perrished in my brothers car with a peice of metal bar i cut out of a fence and cable ties. The mechanic wondered why my brother wanted it replaced. Also sorted a boost leak in my old ranger with gaff tape and probably 200 cable ties. It worked, also got a good laugh when passed around at the mechanics.
Had my accelerator cable bust on my XCGS 302 about 70 km from home so I used a piece of electrical cable to the carb under the bonnet and through the drivers window for a hand held throttle ...... it was fun driving through town in a 4 speed manual
XC GS OLD SCHOOL MUSCLE ![]() Audi A4 S-line quttro Xc falcon Previous fords- xc falcon 500 ,250 x flow 3 speed xc gs worked 250 x flow 4 speed xa Fairmont 302 auto wagon xb falcon 250 log auto 4 door xb falcon 200 log auto ute xc gs project - had to sell :-( xc gs 302 4 speed 4 door xc gs 351 auto 4 door zf fairlane 302 auto zk fairlane 250 x flow carb auto zl fairlane 250 x flow EFI auto xg ute , BA falcon dedicated gas xd, xf x 3 ,ea,eb,ef,au x 3,telstar tx5 |
do a youtube search 'bush mechanics' our local boys know how to keep things running...
Dont p i s s off older people. At our age the term Life in Prison is not a deterrent |
Cabover nut
Had a few of beauties driving the motorhome, best ones are driving down from Coffs to Wangaratta and got within 3km from base, snapped alternator bracket, loosing water pump, belt in the process causing a overheat. Pulled the bracket, screwed brick wall ties to either end, reinstalled with nylon rope I had as a temp fan / alternator belt for the long 3km drive home.
Blew a front steer tyre on the Buckets Way, breaker bar wasn't getting the wheel nut loose and could not get the jack under the front axle to lift anyway. Tyre was holed and toasted so picked heaps of wet grass on the side of the road and stuffed it into the hole, managed to drive to Nabiac (at about 10km/h)) for a new tyre. Tyre guy said I saved the split ring wheel by doing so and was impressed. The wet grass tyre trick I had used while out mountain biking and pinch flatting several tubes. Down at Koroit I managed to jam the gearbox up, no gears, entering an overnight stop at the CP, next morning with wire got one gear working (3rd) and was heading for a truck mechanic in Warnambool, spotted one of his worker in a ute so communicated with him (hand gestures) that I was heading there in only one gear which meant I couldn't stop so he escorted me in avoiding traffic straight to the yard.
#12 | ||
Aluminum foil gasket from power steering hose to steering box.
lance
Used the peak of a baseball bat cut to shape, for a thermostat gasket on the Ford D series engine in my parents’ boat. It was in there nearly a year.
1971 XY GTHO replica electric blue 4spd black trim Sold 1984 XE Esp Fairmont Ghia 6cyl Sold 1984 Xe Fairmont Ghia 6cyl Efi Sold 1966 Xp deluxe sedan Sold Mk2 escort sedan 1600 Sold Mk3 cortina 2 litre Sold 1975 Xb Falcon 500 250/ column auto 94000 kms Current |
#14 | ||
Ratchet strapped the front axle of a Landcruiser to the leaf spring after the u bolts snapped. It located fine on the centre bolt and drove like nothing ever happened.
2006 BF RTV 1980 HZJ 60 |
#15 | ||
![]() Join Date: Dec 2006
Did similar but snapped the whole diff banjo in half, tied up with boat anchor chain, drove 200kms on dirt back to civilization very slowly...
#16 | ||
Falcon RTV - FG G6ET
![]() Join Date: Mar 2007
Met a bloke on the Nullabor in'72, who had a wooden piston in his Norton. He had made it earlier in the year out of Gidgee up in SW QLD.
May still be going, considering how hard that timber is, having hit it with an axe one time.
BAII RTV - with Raptor V S/C. RTV Power FG G6ET 50th Anniversary in Sensation. While the basic Ford Six was code named Barra, the Turbo version clearly deserved its very own moniker – again enter Gordon Barfield.
We asked him if the engine had actually been called “Seagull” and how that came about. “Actually it was just call “Gull”, because I named it that. Because we knew it was going to poo on everything”. |
#17 | ||
Cabover nut
Sound like Sth American Purple Heart, beautiful hard boat building timber of old. Polishes up like stainless steel, very rare now days. I have a small sample at home.
#18 | ||
Cabover nut
Hi Lance, was that a D series marine conversion or a Ford "Lees". Beaut diesels and very reliable the Lees.
#19 | ||
They built boats of Purple Heart? Dear as poison now - check it out.
#20 | ||
Cabover nut
If you can find it, dear as poison alright.
Mainly ribs and deadwood keels, some below the water planking to keep worm at bay, rubbing strakes and spars. A bit heavy for standing spars but idea for bowsprits, bumpkins and davits.
#21 | |||
Bolt Nerd
Ticos use ir for everything from plates, bowls, ornaments... to bigger stuff like table tops and bed heads... Beautiful when highly polished Though I’ve never seen a boat made out of it?.. Maybe too dense?
Current vehicles.. Yamaha Rhino UTV, SWB 4L TJ Jeep, and boring Lhd RAV4 Bionic BF F6... UPDATE: Replaced by Shiro White 370z 7A Roadster. SOLD Workhack: FG Silhouette XR50 Turbo ute (11.63@127.44mph) SOLD 2 wheels.. 2015 103ci HD Wideglide.. SOLD SOLD THE LOT, Voted with our feet and relocated to COSTA RICA for some Pura Vida! (Ex Blood Orange #023 FPV Pursuit owner ![]() |
#22 | |||
Turned out the owner had done a run around Lakeside race track after getting the tailshaft balanced and bought the car back because of a vibration, which the mechanic was at a loss to fix, until I pointed to the rear gearbox mount being a block of timber. |
#23 | ||
Cabover nut
Yeah being a boatbuilding timber and building a compete boat out of it would be two different things.
My old boat had ironbark scantlings with NZ Kauri planking (carvel). In a trawler of 34 foot it would be too heavy for its own good if it was all built completely of ironbark.
