Old 20-05-2020, 11:56 AM   #1
Kylie
Default Cortina MK2
Hi
wondering if someone can tell me anything about my cortina I found a prefix number which is CN7820B
Kylie is offline   Reply With Quote Multi-Quote with this Post
Old 20-05-2020, 12:05 PM   #2
gutza
Default Re: Cortina MK2
Hi Kylie.
You may also want to post it in this part of the site as well.
It's aimed at Escorts, Capri's, Cortina's etc ........
https://www.fordforums.com.au/forumdisplay.php?f=80
All the best and welcome.
Looks like somebody already did it
gutza is offline   Reply With Quote Multi-Quote with this Post
Old 20-05-2020, 07:48 PM   #3
simon varley
Technical Contributor: For members who share their technical expertise. - Issue reason: Bringing sanity to the Everest threads.
where did you find this number? it's nothing obvious to me.
simon varley is offline   Reply With Quote Multi-Quote with this Post
Old 21-05-2020, 06:55 AM   #4
Kylie
It’s stamped on the drivers side near the shocky
Old 21-05-2020, 11:30 AM   #5
simon varley
My escort is CK which I believe denotes Homebush plant in Sydney. Can't find anything about CN though. Looks like Cortina were assembled in Broadmeadows
Old 23-05-2020, 09:36 PM   #6
Capriman
formerly ford3000gt
Capriman's Avatar
I'd say that your CN7820B is more than likely the original engine number fitted to the car when built. If it was assembled at Broadmeadows, as Simon Varley suggests, the code would be CG or CL where C=Ford Britain export CKD and G=Passenger vehicle line OR L= truck assembly line. The truck line was only used for Capri Convertibles from 1988 though. As far as I'm aware all early Escorts, Cortinas and Capri's were assembled at Homebush, code K.
Current ride:
'83 Mk.3 Capri, 2.8i, 5-spd
Capriman is offline   Reply With Quote Multi-Quote with this Post
Old 01-06-2020, 08:22 AM   #7
chappy60
the cn number on the shocky tower is the engine number
which refers to a gt engine 1600 if it started with cm it would
be a standard 1600
chappy60 is offline   Reply With Quote Multi-Quote with this Post
Old 06-11-2020, 05:31 PM   #8
Changa
Changa's Avatar
Kylie,
your number you found is the VIN number, this should match your engine number on early Mk2 cortinas (if orig eng) This number will NOT match up with your ID numbers stamped on your ID plate or on the radiator support panel.
Going by my findings, a VIN starting with CN was usually a GT model. Is yours a GT ?
Seeya ! Wouldn't wanna be ya !
Changa is offline   Reply With Quote Multi-Quote with this Post
