Old 23-04-2021, 11:28 AM   #1
Froger
Default Festiva Trio not starting after running
As in title I have a 1999 WF Festiva Trio 1300 ..
Starts no worries when I leave home runs fine , get to where i'm going 15 minutes later turn it off do what I have to do hit the key turns over doesn't start , try to start a couple of times still no start , let it sit for 10 to 15 minutes starts again... Some days it doesn't have any troubles at all ..
This showed up after the Heavy rain we had recently , but I sprayed the dizzy and an all other connection with WD40 and it started , next time it stopped and I sprayed again it didn't start
I plan on taking some electrical wire with alligator clips and connect to the coil lead unplugged at dizzy to check for spark when I turn it over when it does it again ...
Do these cars have a fuel filter that maybe clogging up ?
Could the coil be close to Fried ?
Any suggestions would be much appreciated as it's great running little car Regularly Maintained .
Cheers ALL
Froger is offline   Reply With Quote Multi-Quote with this Post
Old 23-04-2021, 01:00 PM   #2
adyadad
Default Re: Festiva Trio not starting after running
It may be a long shot but I used to have a Mazda that did exactly this. Turned out it was voltage drop in the starting circuit. I had a relay put in to make sure I got 12 volts from the key (small wire onto starter solenoid) and never had a problem again.
adyadad is offline   Reply With Quote Multi-Quote with this Post
Old 23-04-2021, 06:23 PM   #3
Froger
Thanks adyadad will look at that for sure ..
Old 23-04-2021, 06:29 PM   #4
adyadad
The older the car, the more likelihood of voltage drop. It's an easy job to do yourself. Just a normal small Bosch relay, some wire and connectors. 10 minutes max.
Old 24-04-2021, 11:30 AM   #5
GTLEGEND
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Every advice post I visit where OP are seeking advice for their new vehicle, he is there and adds valuable support and advice for rectifying the problem. Really is a Legend. Technical Contributor: For members who share their technical expertise. - Issue reason: The quality of information he provides is in depth and highly valued by those posting questions.
Sounds like a possible dizzy module to me, that is if the cap and rotor are ok?
GTLEGEND is offline   Reply With Quote Multi-Quote with this Post
