Old 27-08-2021, 11:44 AM   #1
sprintman1
Default Need a mechanic - Canberra
Need a knowledgeable member/mechanic that’s interested in looking at a BA that won’t start (backfiring), paid job of course. New battery, plugs and factory coils fitted but no change. Apologies if this is the wrong section to ask this.
sprintman1 is offline   Reply With Quote Multi-Quote with this Post
Old 27-08-2021, 11:55 AM   #2
gutza
Default Re: Need a mechanic - Canberra
Hi sprintman.
Might get more responses in the AU-BF forum.
Is the car on dedicated gas or dual fuel ???
Does the car start then immediately stall ??
Cheers.
gutza is offline   Reply With Quote Multi-Quote with this Post
Old 27-08-2021, 12:13 PM   #3
I’d suggest checking the mechanical timing if all external issues are run to ground.
Citroënbender is offline   Reply With Quote Multi-Quote with this Post
Old 27-08-2021, 01:03 PM   #4
sprintman1
Originally Posted by gutza View Post
Hi sprintman.
Cheers.
Petrol. Random firing doesn’t actually start
Old 27-08-2021, 01:37 PM   #5
gutza
Hi There.
1. Any mechanical work done recently ?? As Citroen said. The timing may be off. Especially with the backfire on a petrol engine.
2. My initial thought was a bad vacuum leak. Although the car should start, then stall.
3. Immobiliser light out before cranking ??
4. Check for spark.
5. Get noid light to see if injectors are "firing"
6. Fuel pump, filter OK ??
7. Crank Position Sensor.
8. Check battery voltage with multimeter. When cranking if voltage drops below a certain point, the computer will shut off. Varies with different cars / brands etc.
Can't do much more without seeing in person.
Sorry.
All the best.
Old 27-08-2021, 02:11 PM   #6
gutza
Just another thought.
The coil pack plugs are on the correct cylinder (s). No offense.
Old 27-08-2021, 04:45 PM   #7
sprintman1
Cables are pretty much set in position. It had the same problem before plugs/coils replaced.
Old 27-08-2021, 10:19 PM   #8
XR Martin
XR Martin's Avatar
Blocked cat?
Unbolt the exhaust from the manifold and see if it will start.
2004 BA wagon RTV project.
Old 27-08-2021, 10:37 PM   #9
sprintman1
Originally Posted by XR Martin View Post
Blocked cat?
Why would that happen like overnight? Drive fine then next morning wouldn’t start.
