Old 21-01-2022, 11:44 AM   #1
Late braker
Default Cold min level BFXR6 n/a
Should I add a bit of demineralised water to the tank just to get the level up to cold max? When engine is cold it’s on the cold min level. Should I worry? Thanks BF XR6 n/a
Late braker is offline   Reply With Quote Multi-Quote with this Post
Old 21-01-2022, 12:09 PM   #2
J Arthur Rank
Default Re: Cold min level BFXR6 n/a
Where is in when engine is at operating temp?
I keep my cold level right in the middle of the two and when hot, it is just above the max line.
J Arthur Rank is offline   Reply With Quote Multi-Quote with this Post
Old 21-01-2022, 07:45 PM   #3
Late braker
Ok when it’s at normal operating temperature and idling the level is just slightly under the cold max line. Seem ok?
Old 21-01-2022, 08:37 PM   #4
J Arthur Rank
I think so mate. As long as it is between the two marks when cold it should be sweet. I usually check every week or so to make sure the cold level is still the same.
Old 21-01-2022, 08:41 PM   #5
Late braker
Thanks- I do usually check it regularly although not for a while and whilst it’s on the cold min level or very very slightly under its nowhere near the hot max line when running at normal temp and idling..
