Old 05-07-2022, 07:39 PM   #1
asimplelife
mechanical novice hopeful
Default Remove AU2 Hood/Bonnet Front Lip/Trim with Rusty Nuts
I can't find a thread already for this? Maybe the info is buried in a more general thread somewhere?
Its for a high series bonnet.
And I've got 2 with the same problem.
The Lip/Trim is plastic.
There are 5x 10mm nuts under the front edge of the bonnet.
Then there is a double headed screw/bolt, which screws into the plastic Lip/Trim, then bolts through the bonnet to the nut.
Obviously moisture gets into the bolt/not and they seize.
The screw then undoes from the plastic Lip/Trim.
Leaving the double headed screw/bolt attached to the nut and stuck in the bonnet.
I've tried vice grips to clamp the screw head.
But I can't get enough purchase to break the thread.
Have tried WD40 with no improvement.
Before I give up and grind them out, are there any obvious solutions I am missing?
Thankyou.
asimplelife is offline   Reply With Quote Multi-Quote with this Post
Old 08-07-2022, 10:07 PM   #2
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
Default Re: Remove AU2 Hood/Bonnet Front Lip/Trim with Rusty Nuts
a bit of heat
Old 17-07-2022, 10:36 AM   #3
asimplelife
Thankyou for the suggestion. In hindsight I should have thought that through for myself. Haven't been able to make time yet to try it but will report back when I have.
Old 17-07-2022, 06:05 PM   #4
Uncle_Ken
Uncle_Ken's Avatar
Just watch the paint.
Old 17-07-2022, 06:17 PM   #5
asimplelife
Well, the good new is on both bonnets, the paint is already stuffed
