Old 27-11-2024, 05:36 PM   #1
Default Holesawing Steel Plate
I’ve got to organise a custom tool, to counterhold a crankshaft.
It’s basically a ring of steel 8-10mm thick welded to a handle around 25mm wide by the same thickness by 400mm long.
The ring part will have multiple 8mm fixing holes drilled on a 49mm PCD. It will be about 70mm OD and needs a centering bore of 35mm.
Cutting the handle, ring OD and drilling the 8mm holes present no issues. I’m just wondering about real world approaches to drilling the centre hole, Google is one thing but I’m interested to hear from people who’ve sawn holes like that in basic garage workshop situations, with commonplace tooling. As in, will a bimetal holesaw do the job if used slowly and gently?
Old 27-11-2024, 06:10 PM   #2
Default Re: Holesawing Steel Plate
So material depth and hole size and amount of holes?
Either way trefolex will be your friend
Old 27-11-2024, 06:21 PM   #3
simon varley
Technical Contributor: For members who share their technical expertise. - Issue reason: Bringing sanity to the Everest threads.
have you considered laser cutting the whole thing?
simon varley is online now   Reply With Quote Multi-Quote with this Post
Old 27-11-2024, 07:05 PM   #4
hawke
hawke's Avatar
I have a basic garage workshop, so would cut such a hole with lathe or mill. Mill will easily do holes on that PCD.
hawke is online now   Reply With Quote Multi-Quote with this Post
Old 27-11-2024, 07:30 PM   #5
We have just a drill press, welders, bench grinders, small linisher. Milling and turning are farmed out to a semi-retired fellow in the area.
Simon - I can’t see myself finding it laser cut by 4PM tomorrow, off a paper sketch, for $120 or so outlaid. Would be great if I could!
Old 27-11-2024, 08:13 PM   #6
Interceptor
HSV - I just ate one!
Interceptor's Avatar
Wouldnt be the first time i've used a hole saw, plenty of lume and even more patience with a holesaw, just go slower than the federal government
I dont care if some prius driving eco-hippy thinks its politically incorrect for me to drive a V8..... I'm paying for the fuel!
Interceptor is online now   Reply With Quote Multi-Quote with this Post
Old 28-11-2024, 08:20 AM   #7
whynot
whynot's Avatar
It is possible to do a test hole on a scrap bit of identical metal first? Hole saws are great on the softer metals, but struggle on the harder grades. Biggest problem might be the hole saw wandering around a little with hand tool application, even with a pilot hole. If it is slow going the pilot drill starts digs into the sides of its pilot hole, expanding it, resulting in drill wobble. What type of accuracy do you need, both for hole location and hole size?
whynot is offline   Reply With Quote Multi-Quote with this Post
Old 28-11-2024, 09:06 AM   #8
I’m essentially knocking off this: https://www.ozwidetools.com.au/bmw-n...t-holding-tool
Centre bore accuracy required is “tidy” as opposed to “sloppy”. Highly scientific terms.
Counterhold torque loading is 300Nm, hence the use of thicker steel plate.
Old 28-11-2024, 09:26 AM   #9
Charliewool
Bolt Nerd
Charliewool's Avatar
Do you have oxy?
Make up a gadget similar to this..
(Doesn’t need to be as fancy!)
Centre punch in centre of circle to be cut, drill a small pilot hole on perimeter of diameter to start the cut, and cut your circle!
Current vehicles.. Yamaha Rhino UTV, SWB 4L TJ Jeep, and boring Lhd RAV4
Bionic BF F6... UPDATE: Replaced by Shiro White 370z 7A Roadster. SOLD
Workhack: FG Silhouette XR50 Turbo ute (11.63@127.44mph) SOLD
2 wheels.. 2015 103ci HD Wideglide.. SOLD
SOLD THE LOT, Voted with our feet and relocated to COSTA RICA for some Pura Vida!
(Ex Blood Orange #023 FPV Pursuit owner : )
Charliewool is offline   Reply With Quote Multi-Quote with this Post
Old 28-11-2024, 09:45 AM   #10
That’s a nifty gadget! I haven’t seen an oxy cutter head around though, and don’t have one at home.
Old 28-11-2024, 09:55 AM   #11
Charliewool
Bolt Nerd
You get what I mean though?… You set the pointed tip distance to centre of oxy cutting tip to 1/2 the diameter of the required hole size and rotate the torch with the pointer tip in centre-punch.
Pilot hole on the circumference is to start your cut and avoid blow back.
Old 28-11-2024, 10:25 AM   #12
Yes, totally understand the idea and have new tool envy.
Old 28-11-2024, 11:13 AM   #13
Interceptor
Geez.... the one I made in high school is still somewhere in my toolbox!
Old 28-11-2024, 12:27 PM   #14
AMB
Technical Contributor: For members who share their technical expertise. - Issue reason: Always has a helpful answer in the technical sections, wether it's giving information on a simple diagnosis with a small issue, Helping someone fix their car if they are stuck on removing/installing something, or just need information on what works how.
....needs a centering bore of 35mm. ....will a bimetal holesaw do the job if used slowly and gently?
Yeah, should do, buy a good quality one to make it easier. I've done similar, even stainless. I would stop half way through, flip it over and finish from the other side. Just dont overheat the blade. Sometimes I air cool with compressor air while cutting, it helps a lot and sometimes easier and less messy than trying to keep cutting oil up to it, depends on the circumstances.
AMB is offline   Reply With Quote Multi-Quote with this Post
Old 28-11-2024, 02:14 PM   #15
Charliewool
Bolt Nerd
Ditto… left mine at work when I retired
Old 28-11-2024, 02:37 PM   #16
ozrunner
Go for it it's a piece of cake. Done this many times in 10mm plate.
But you must use a quality hole saw and a proper drill press for accuracy etc and at a medium speed and use plenty of lube as it will get hot. I usually use WD40. Used trefolex as well but its messy compared to WD40 and stinks
ozrunner is offline   Reply With Quote Multi-Quote with this Post
Old 28-11-2024, 03:45 PM   #17
cs123
cs123's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: Can't think of anyone more deserving. Russ Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For all the technical support behind the scenes. Tech Writer: Recognition for the technical writers of AFF - Issue reason: Technical submission
35mm annular cutter in the drill press?
I love Holdens....
cs123 is online now   Reply With Quote Multi-Quote with this Post
Old 28-11-2024, 05:13 PM   #18
Jack91
Jack91's Avatar
I've gone through 16mm s/s plenty of times with a holesaw in a geared head press.
Just clamp it straight to the deck with blocks and lock everything up, finished size will end up a mill or so bigger.
I exclusively work with stainless and I find cutting oil better than trefolex (has a better cooling effect being able to submerge the cut), but whatever you use just use a lot of it. You'll be surprised what even the cheap Sutton holesaws can do if you keep them relatively cool and clamped up tight.
Jack91 is offline   Reply With Quote Multi-Quote with this Post
Old 28-11-2024, 05:52 PM   #19
I’ve only got partway through the job today - everything else possible, jumped in front of it.
I bought 8mm ground finish plate, have done the internal setout but not marked the periphery for cutting to shape. My own drill press and the workshop one are both older Asian made belt drive units - all pilot holes went fine, so I’m confident. Filing corners of the 1/2” square recess for the breaker bar end, will be a small challenge for the ego to make neat.
This is the thickest I’ve played with in steel, previously only got up to 4mm black plate to make a customised exhaust bracket. I appreciate the seasoned advice/encouragement from all.
Old 28-11-2024, 08:16 PM   #20
John 13
Cutting/cooling compound. Agree with the importance of cooling cutting blade, particularly when cutting other than sheet metal. In the latter case I have, when available, always used trefolex.
The latest Trefolex is not at all as effective as the previous/original version, however it does not carry the same significant health warning.
John 13 is offline   Reply With Quote Multi-Quote with this Post
Old 28-11-2024, 09:19 PM   #21
I’ve had my tin of Trefolex since about 1989. What’s the hazard in it - thought it was lard based?
Old 28-11-2024, 09:29 PM   #22
simon varley
what about a step drill, rather than a hole saw??
https://www.totaltools.com.au/199413...l-bit-48899395
Old 28-11-2024, 09:40 PM   #23
Trefolex, yes get used to the smell and more then one quality holesaw, as in starret or suttons, so if carefull 1 will do, if it does you have a spare. Ive never had any great success using christmas trees on anything past 3mm steel because they leave a taper and also dont tend to perform on thick material.
Old 28-11-2024, 10:11 PM   #24
351buzz
351buzz's Avatar
A bi metal hole saw will do it no worries.
If you don't mind buying the odd tool you could get a practool super drill
https://practool.com/
Can set it up to any size hole you want.
351buzz is offline   Reply With Quote Multi-Quote with this Post
Old 28-11-2024, 10:20 PM   #25
It's now mainly pine oil with less than 1 % ethanol and methanol. But I think the pre 1982 stuff like many CRC products of the time such as it Brakleen contain a significant bit of carbon tetrachloride and/or tetrachloroethylene . I hate to think how much brakleem fumes I inhaled trying prevent inhalation of asbestos brake pad dust. And then the methylene chloride and other chlorides they replaced the carbon tetrachloride with has proved to be as nearly as equally hazardous to the health.
Old 28-11-2024, 11:01 PM   #26
Of course the $400 solution is the Vevor Mag Drill Press that comes with 11 broach bits or something similar.
Old 28-11-2024, 11:06 PM   #27
We are talking drill press yeah, not raw dogging with a cordless?
Old 29-11-2024, 12:11 AM   #28
This: https://www.youtube.com/watch?v=pLbBrX--W3o&t=245s AND
Old 29-11-2024, 05:51 AM   #29
Correct, as I mentioned earlier; belt driven, not geared head. I have three arbors and will probably use a $30 Sutton bimetal holesaw - that will definitely work with one of them.
Old 29-11-2024, 08:06 AM   #30
Charliewool
Bolt Nerd
Surprised no one’s mentioned a slugger?
Really need a mag drill with the 19mm click-in shank, but at a pinch can be used in a normal chuck (albeit 3/4” capacity)
They absolutely eat steel plate!
https://www.tradetools.com/renegade-...RoCfgcQAvD_BwE
