31-01-2025, 05:49 PM | #1 | ||
This is not permanently at tank pressure, is it?
I mean, if the hose is ripped in an accident, the tank contents cannot escape via the connected hose used to fill it? I’m assuming it has a check valve at the tank end fitting. Just checking before I accidentally blow a suburb off the map this weekend. |
31-01-2025, 06:16 PM | #2 | ||
Correct. Tank has a fill valve inside it. That's the valve that shuts off when the tank is full via a float. It is a check valve.
The fill point also has a check valve that will hold pressure in the line. It can be bled off by pushing the centre bit in with a screwdriver to release the pipe pressure. Where gloves when you do this as it will freeze burn your pinkys |
2 users like this post: |
31-01-2025, 06:29 PM | #3 | ||
Thank you. I was uncomfortable just “assuming”, considering the tank I need to remove is still holding about 15-20 litres of gas.
Yesterday, 08:35 PM | #4 | ||
Turn tap off, crack pipes slowly and no drama.
Dont Smoke... |
