I've got a Fiesta here having issues with locks, car audio and most urgent the read indicators not working.
After some research and checking the globes etc it seems like the BCM is highly suspect. I've hooked up ForScan hoping to download the keys on it incase I need to replace it and re-sync it to the car. I want to take it out and check the electronics inside but was hoping to "save" the data inside it first. On ForScan it does recognize the issues I described but I can't seem to get to the screen when I can save the data. I've attached the images showing the different parts of ForScan I see, but it doesn't seem like I can select the BCM - only the "backup" version. ![]() ![]() ![]() Is this likely because the BCM is cooked? Or do I need to get something else. If I need to replace it with a 2nd had one, how do you sync the new one up back to the car? |
on the config screen, if your hit the run arrow, does the save icon enable? I'm trying to remember what I've done before...
