Would somebody be able to share the BCM pinout / wiring diagram?
Thanks in advance legends. |
Chairman & Administrator
![]() ![]() Join Date: Dec 2004
I've added what I can find to the Tech Portal HERE
The WQ Wiring diagrams are also in that portal if you want to trace the rest yourself.
Observatio Facta Rotae
Thank you that was helpful, do you happen to have the numbers of of the pins for the connector, specifically the blue one? Your sheet has the information I need, but the plugs have a non intuitive arrangement which leave is ambiguous which ones are what numbers.
Edit: Oh I can see you've got the wire colors there - I will match them up with the wire colors in the car. |
