Sly like a G6
Just wondering if anyone has typical compression test figures for their I6. Tested mine today, all cylinders test between 1500 and 1550 kPa (roughly 220 to 225 PSI in the old money). The manual says it should be 1010 kPA minimum and all within 100 kPa. Are mine a bit high?
The Frankenfalcon... AU1.5 Wagon, BA brakes, AU2 booster, BA2 XR6T engine, stock from airbox to turbo, 8psi/98 octane tune 240RWKW, BF XR6T cat, quiet 3" zorst, Pex BSO660 & BSO439 mufflers, 84 db, built BTR box, 3.08 LSD, Emer SVI LPG, AU1 XR8 alloys, Momo wheel, JVC KDR746BT head unit, Aerpro steering wheel control wiring. Sleeper, anyone? |
compression is fine stop worrying
Sly like a G6
Thanks, but I always worry a bit about forking out large chunks of cash. I'm planning to add forced induction to this engine soon and was moved to comp test it after a mechanic mate queried the wisdom of boosting a unit with nearly 320,000k's up. I think I'll just do it...
#4 | |||
#5 | |||
Sly like a G6
If I go with a 6 PSI turbo, the Ford flash tuner bloke in Thornton will be doing the job so the timing will be safe before it turns a wheel. If I go with the CAPA Powerdyne kit the car can be safely driven to him for tuning either limiting the revs to 2500 or just by disconnecting the belt.
That being the case with that many Km's did you check for leak down? comp. may show fine but you have to keep watching it for 30secs to see if there is any leak down. You will always get a tiny bit but if it is at a reasonable rate then this will be multiplied by more cylinder pressure.
Sly like a G6
OK will check that out. Does leak-down indicate worn rings or valves? Head is only 65,000 km old so valves and seats should still be OK.
A leak down test will show whether you have leaking inlet valve or exhaust valve or leakage past the rings
#9 | |||
#10 | |||
Sly like a G6
