Old 05-06-2005, 04:04 PM   #1
EA_Bender
Hmmm Gold!!!
EA_Bender's Avatar
Default Dizzy Direction
me again...
im doing the MPI conversion next weekend :1syellow1 one of the few remaining questions i have is about the orientation of the dizzy. On the cfi models, the tfi faces the rear of the car, on the mpfi models, it is rotated 90 degrees clockwise so it faces the front left wheel.
Do i need to do this?? if i dont, then sweet, if i do, is it just a case of lifting the dizzy out and rotating it?
thnks in advance
bender
1990 EA Series 2 Fairmont, Low Springs and shocks, 17 x 7 Advanti Flash Mags running on Falken rubber :, EL XR8 Sway Bars, NGK Iridium Plugs, New Trip Comp, Pacemaker 4480, 2.5 system 4L ED engine with surecam
Now Sporting - OED666's 202+ RWHP engine!! :dj: fully
EA_Bender is offline   Reply With Quote Multi-Quote with this Post
Old 05-06-2005, 05:45 PM   #2
SileNceR
02/90 EA II Fairmont
SileNceR's Avatar
I didn't change mine.
211RWKW EA
SileNceR is offline   Reply With Quote Multi-Quote with this Post
Old 05-06-2005, 05:50 PM   #3
InitialD
Low and Loud
InitialD's Avatar
You are fitting the MPFI dizzy when your doing the conversion right? ;)
(yes i know you dont HAVE to, but you should)
With MPFI and CFI the dizzy backet is in a different position. you will find there is a bolt hole on the oposite side of the dizzy for MPFI (closest to coil side)
You should move the dizzy to the MPFI position as you would see in the Workshop manual as it makes life harder i found in the CFI position... cant remember why thou :P
Old 05-06-2005, 05:55 PM   #4
jedaarr
jedaarr's Avatar
Location: Nowra (Southcoast) N.S.W. Beutiful beaches no smog & plenty of grog & yes that is my dog.
Originally Posted by EA_Bender
me again...
thnks in advance
bender
U can use the cfi dizzy no problem & its easier to move than
the mpi as the bolt can be undone from left to rotate.
HOME BREW BEER SWINDLING PROFFESIONAL P-HEAD.
TO MANY YEARS IN THE MAKING : :1syellow1
jedaarr is offline   Reply With Quote Multi-Quote with this Post
Old 05-06-2005, 06:49 PM   #5
EA_Bender
Hmmm Gold!!!
EA_Bender's Avatar
um, id just planned on using my cfi one.. im not sure exactly what the difference is between them.
so basically i can use my current cfi one AND leave it in the same position without touching it? is that right?
thnks for the replys
Old 05-06-2005, 10:26 PM   #6
InitialD
Low and Loud
InitialD's Avatar
The MPFI dizzy has a smaller tooth off the spider gear. The car will idle ALOT better with the MPFI one, you can use the CFI one for the time being but id be definitly changing it to the MPFI one, or changing your spider gear in your dizzy to the MPFI one. Your auto electrican can do that for you.
Old 05-06-2005, 11:18 PM   #7
EA_Bender
Hmmm Gold!!!
EA_Bender's Avatar
ok, i might rip the dizzy off the wreck ive been getting my parts off, after u undo the bracket, do they just pull straight out,
hmm, that means im going to have position it all correctly, and ive got no idea what im doing there, i might just get the dizzy but leave the cfi one in till i can find someone that knows what they're doing
do u think it would be easier getting the mpi dizzy and gettign all the timing set up properly or getting a new spider gear put in?
Old 05-06-2005, 11:27 PM   #8
InitialD
Low and Loud
InitialD's Avatar
Providing your MPFI dizzy is in good nick, its easier to change that then swapping spider gears. You can just leave it for the time being then get a mechanic to change it for you ;) if you dont have a timing light and experience in doing it
Old 05-06-2005, 11:50 PM   #9
jedaarr
jedaarr's Avatar
Default Dizzy
The mpi & cfi dizzy are total mirror reverse of eachother. U can not
rotate the dizzy at all, as tfi etc is on opposite side.The only reason
ford origianally reveresed the dizzy was so u could remove isc solenoid
housingto gain access to rotate dizzy. (MPI)
With the cfi Dizzy is so easy to rotate for timming as the nut is easy to undo being on left side, as it is not obstructed by injector manifold.
Both dizzy are identical to look at, only reverse of each other so dont
listen to tales of differences i rung ford & this is a fact.
They are identical in structure.
Old 06-06-2005, 12:51 AM   #10
InitialD
Low and Loud
InitialD's Avatar
Id go back to your home brew cause I think your wrong. ive got a MPFI dizzy and CFI dizzy in the garage and they are IDENTICAL cept for the spider gear :
You have have it on the Left or Right with the MPFI dizzy, ive had it on both and I can get to the bolt on the RHS easy as with a long extention.
Old 06-06-2005, 05:25 PM   #11
EA_Bender
Hmmm Gold!!!
EA_Bender's Avatar
the dizzy's are exactly the same, im looking in the manual right now..
i think what ill do i leave the dizzy exacly how it is, ie. cfi and in the same position, see if the one at the wreckers looks ok, and put that im when someone can help me with the timing cause i have no idea.
if i dont change anything right now, i shouldnt have any troubles, maybe just a bit of a rough idle and ill get the rest sorted out later
just to add onto this, why were the positions moved in the first place? did it foul on something?
Old 07-06-2005, 05:52 PM   #12
EA_Bender
Hmmm Gold!!!
EA_Bender's Avatar
also... do i need to get a longer air con belt due to the position changing from the cfi to mpi or is there a tensionor on that belt somewhere?
Old 07-06-2005, 07:54 PM   #13
SileNceR
SileNceR's Avatar
there's a tensioner, between the balancer and the compressor.
belt is the same.
211RWKW EA
