Old 09-06-2005, 01:05 PM   #1
Simmo
White Lightning
Simmo's Avatar
Default adding a trans cooler...few Qs
i bought a trans cooler off ebay and im gonna fit it this weekend. i do have a couple of questions though. i can see where the pipes fit and everything but when i add it its gonna be empty/full of air. will this be a bad thing having the air go through the lines and into the box? or will the air just go where it has to and not effect anything. also since its second hand is there anything i can run though it or try and get in there to give it an internal clean.
Simmo is offline   Reply With Quote Multi-Quote with this Post
Old 09-06-2005, 01:42 PM   #2
EA2BA
PM me if you want
EA2BA's Avatar
just add about 500ml of trans fluid the air wil just work its way out of the system thats all I did
pour some fluid in one end, and hold your finger over it, then twist and turn the cooler to make it come out the other and check it all looks good.
Old 10-06-2005, 12:19 AM   #3
TURBO_GHIA
hmmm boost
TURBO_GHIA's Avatar
if the cooler is BIG bypass the fluid from the radiator altogether
EL TURBO GHIA
GT3582R
WOLF3D
TUNED BY JEM
TURBO_GHIA is offline   Reply With Quote Multi-Quote with this Post
Old 10-06-2005, 12:34 AM   #4
John_LS1
define big. my trans cooler is about 1 1/2 - 2 times bigger than factory. is this big enough to by pass it? ill get some measurements of it.
Old 10-06-2005, 12:42 AM   #5
Damo
my cooler had nothing to do with the radiater, (3speed) it's still conected at the front i just cut the lines and crimped them.
I should pull it off and sell it.
Old 10-06-2005, 12:44 AM   #6
InitialD
Low and Loud
InitialD's Avatar
leave it there damo, its worth nothing being 3 speed
Old 10-06-2005, 07:55 AM   #7
Cobalt_bucket
Blue eyed 17sec bucket
Cobalt_bucket's Avatar
Well i fit cooler all day every day (especially to BA's)and we bypass the radiator and use a coolers the size of an A4 piece of paper, and since half are cabs there effective, they come as a kit with 3/8 hose and have never had a problem with them, as for using a 2nd hand one i would be strongly against it but since you have already brought it i would suggest flushing the cooler out with K55 (or equivilent) solvent, then fitting it,
if anyone wants a cooler i can sell them to you for $144 plus frieght ( $13.20 over night almost anywhere in aust)
1994 ED fairmont, blue eyed with crow cam, XR6 ecu, chip torque chip, dead and buried
Cobalt_bucket is offline   Reply With Quote Multi-Quote with this Post
Old 10-06-2005, 08:10 AM   #8
Racecraft
they call me Tibbo
Racecraft's Avatar
I agree with Cobalt.. hacksaw off the flared ends then file them smooth and remove the nuts on the factory cooler lines that plumb into the radiator.. Sit your new trans hose (the rubber stuff) in a mug of boiling water to soften them up and push them as far a possible over the factory steele lines.. Use two nicely spaced hose clamps on the end of that hose because it can leak sometimes because you removed the flare...THen just plumb up the front...
I'd give it a hit with some cheap aresol degreaser then blow thru it with some compressed air just incase they is some crud in there, even a blast with the servo air pumper-upper thing will cut it. Just let the degreaser evaporate fully before you fit it.
It is also not a bad idea to fit an inline filter to the hose inlet hose while you are at it.. It is suprising how much stuff it catches even after the trans magnets in the pan.
A4 sized is tiny Cobalt hahaha, I fit the monster A3 sized ones hehe
Old 10-06-2005, 08:15 AM   #9
Simmo
White Lightning
Simmo's Avatar
what kind of filter should i fit? its obviously gonna be different from say a fuel filter as trans fluid is more viscous.
also regarding a reply-less thread in the transmission forums, its off an eb and ive seen the exact same cooler on an EA. but when i looked at my ED it looked a bit different. there is heaps of shit in the way. did the coolers/mounts change from ea/eb to ed?
Old 10-06-2005, 09:45 AM   #10
InitialD
Low and Loud
InitialD's Avatar
4 Speed Auto EA's (Series2) onwards got the Trans cooler as seen on EB, ED got a slightly larger one IIRC
Old 10-06-2005, 10:03 AM   #11
Simmo
White Lightning
Simmo's Avatar
hrm, buggar. well i will still give it a go.
Old 10-06-2005, 05:29 PM   #12
EA_Bender
Hmmm Gold!!!
EA_Bender's Avatar
she'll b right simmo, ill just drill some more holes in ur car!
1990 EA Series 2 Fairmont, Low Springs and shocks, 17 x 7 Advanti Flash Mags running on Falken rubber :, EL XR8 Sway Bars, NGK Iridium Plugs, New Trip Comp, Pacemaker 4480, 2.5 system 4L ED engine with surecam
Now Sporting - OED666's 202+ RWHP engine!! :dj: fully
EA_Bender is offline   Reply With Quote Multi-Quote with this Post
Old 11-06-2005, 10:05 AM   #13
spope
spope's Avatar
Not standard they didn't. Only if you got a towpack fitted when the vehicle was purchased.
I don't understand why you would want to bypass the radiator cooler?
It's just as easy to get the correct fittings so you run it inline with the radiator - then you are pretty much safe from leaks, cause you will still have the flared ends on the pipes.
spope is offline   Reply With Quote Multi-Quote with this Post
Old 11-06-2005, 10:13 AM   #14
Psycho Chicken
Psycho Chicken's Avatar
I think he means the 4 speed cooler is larger than the 3 speed one.
Old 11-06-2005, 11:17 AM   #15
InitialD
Low and Loud
InitialD's Avatar
he asked why the ED one was different to the EA, i said why ;)
Old 11-06-2005, 07:42 PM   #16
Racecraft
they call me Tibbo
Racecraft's Avatar
Because the tank splits and leaks water and coolant into your transmission destroying the friction bands and rendering the g/box good for the scrap heap. Add to the fact that an external air cooler is 10 times more efficent than running your oil beside something that is nearly at boiling point. Also the external trans cooler increase the volume of fluid in the system lowering the temperature even more...
Old 11-06-2005, 11:36 PM   #17
LUXO_8
windsor user
sounds good i might get mine set up like that....
but i'd prefer to have a ridge on the lines where the hoses go on though......
would somewhere be able to do the ridges? like if i took the car there....
Old 12-06-2005, 11:27 AM   #18
Psycho Chicken
Wayne just get a pipe flaring tool.
Old 12-06-2005, 11:51 AM   #19
INJECTED_250
Custom user title
INJECTED_250's Avatar
Yup... i wouldnt ran it threw the radiator cooler.. THey split and destroy autos buy filling it up with water.. and youre coolng system gets filled with oil 2....
INJECTED_250 is offline   Reply With Quote Multi-Quote with this Post
Old 12-06-2005, 11:52 AM   #20
LUXO_8
windsor user
lol, you can get them??????
there you go
Old 12-06-2005, 11:59 AM   #21
Racecraft
they call me Tibbo
Racecraft's Avatar
some of the kits come complete with a female brass joiner to screw over the factory radiator inserts... The flare isn't that important if you get the hose on far enough.
