14-06-2005, 10:14 AM | #1 | ||
likes falcon's
was there such a diff ever released? and if so wat model
www.carhubsales.com.au |
14-06-2005, 10:23 AM | #2 | ||
TL40 Wagon?
Well the LSD centre would fit any ratio of course.
I can only be sure there wasn't a 3.08 LSD as option or standard in any AU series. Before that maybe. |
14-06-2005, 10:44 AM | #3 | ||
The one and only
I think they were available in 3speed EA's.
Most commodores run them! They are normally removed for 3.45.
1992 DC LTDHO 360rwkw built by me Tuned by CVE Performance Going of the rails on a crazy train Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
14-06-2005, 10:48 AM | #4 | ||
hibernating
i think 3speed ea's had 2.77 lsds or 2.92 possibly?
14-06-2005, 12:23 PM | #5 | ||
likes falcon's
eas and xf's mainly had 277 ghias had the lsd std, 292 was an xf option but never heard of one in an ea
14-06-2005, 12:35 PM | #6 | ||
Awake after dark
I've got one in my XE Ghia
Every time I learn something new, it pushes some old stuff out of my brain His Car: XE Fairmont Ghia - For Sale Here Her Car: ED Fairmont - Lowered, Pioneer stereo, Sony XPlod speakers, Big Exhaust & more |
14-06-2005, 03:08 PM | #7 | ||
I had one in my AU, but it was originally a single spinner, just had an LSD hemi put in.
2003 Narooma Blue BA XR6 5spd Manual. Pacemaker 4490 Extractors 2.5" Exhaust High Flow Cat SS Inductions "Growler" CAI Underdrive Pulley Mal Wood H/D Clutch Custom Tune 18" XHP Sabre's 12" Kicker Sub 169.2 rwkw
14-06-2005, 05:23 PM | #8 | ||
Two > One
No car came standard with 3.08:1 LSD iirc. Stock LSD cars were only Ghia/LTD/XR.
2.77, 3.23, 3.27, 3.45 are stock LSD ratios etc
14-06-2005, 06:02 PM | #9 | ||
And 2.92 Dan. At least my XD has one :P
14-06-2005, 06:16 PM | #10 | ||
Two > One
true if you count X series
14-06-2005, 06:29 PM | #11 | ||
likes falcon's
on the topic of low ratios. would the 2 extremes work, say and ef/el manual with long gears with a 277 lsd the lowest ratio
has this been done? imagine the fuel economy a decent motor shouldn't struggle either?
14-06-2005, 06:34 PM | #12 | |||
Shoot.
20V Turbo |
14-06-2005, 06:42 PM | #13 | ||
I swear I've seen 2.92 in some E-series Fairlanes though, hmmmmm maybe I'm tripping.
I knew I should of got an XE and kept my diff, this ratio is shocking. |
14-06-2005, 06:42 PM | #14 | ||
I have 2.77 and EA t5 and it revs way to low, still takes off good, 5 th gear isn't really needed till above 110. 3.08 with an LSD centre would be nice. Don't think they came standard in any e-series.
14-06-2005, 06:46 PM | #15 | ||
Former E-Series Member
I believe the EF Fairmont Ghia had a 3.08 LSD. Also the EA II, EB series I and ED Fairmont Ghias.
14-06-2005, 06:54 PM | #16 | ||
likes falcon's
damo wats it sit at 100, in 5th? u must be getting good fuel economy surely...
14-06-2005, 06:56 PM | #17 | |||
Smile
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again |
14-06-2005, 07:00 PM | #18 | |||
fully *** turboooo
AU1 Forte 178.6rwkw @ 5 psi Highflowed T03, Intercooled Full comp insurance :nutsycuck
14-06-2005, 07:17 PM | #19 | ||
Can't remember exactly what it cost me. I think it was about $300 with a new set of bearing, but I supplied the hemi.
14-06-2005, 07:45 PM | #20 | ||
Shoot.
Damn, 300. Might be better off finding a decent 3.27 LSD :S
20V Turbo |
14-06-2005, 07:49 PM | #21 | ||
Well the bearing kit was worth $120, then LSD oil and an hour or two of labour setting it up. But yes, it was an expensive way of doing it.
14-06-2005, 08:01 PM | #22 | ||
Jack: you'll find that the ghia's will have 3.23 in all examples you gave not 3.08.
3.08 was for cfi cars in the ea 4 speeds so you won't find that in a ghia.
14-06-2005, 08:02 PM | #23 | ||
Custom user title
ef fairmonts had 3.23's ... not sure on ghia
14-06-2005, 09:03 PM | #24 | ||
Mine's a stock SS EL Fairmont diff, not sure what ratio. Would I be better off just buying the LSD centre or trying to find an EF Ghia diff @ the wreckers?
1998 Ford Fairlane - 4.0L
18x8 RJR rims - Tinted - King Suspension - 2.5" D&T Cat Back Exhaust |
14-06-2005, 09:07 PM | #25 | |||
14-06-2005, 09:56 PM | #26 | ||
an auto will give lower revs at 100 ;)
1800rpm @ 100kph with my 3.27 diff. -Dave- |
14-06-2005, 10:04 PM | #27 | ||
Custom user title
but dont forget... calculating auto rpm at 100 kmph using gear ratios is a bit of a mis match.. Even though there is converter lock up its not 100 percent locked and you still get slip... mabie thats why 4th is a bigger overdrive than the manual
15-06-2005, 08:53 AM | #28 | |||
