15-06-2005, 06:08 PM | #1 | ||
Hello there..
Im having a daft time trying to fit an aftermarket head unit into such my 97 El : Now wiring was teh easy bit ironicly.. just what em i dong wrong to get it to screw up into the original housing?? Should i be using the factory holders of the originla head unit.. or are there generic ones i should be buying.?? I say such caue they are tapered in away to fit the standard y tape deck of course What em i missing.. did a quick search ut could only find cable issues so i must be a tool :ymca: Anyone care to shed some light? |
15-06-2005, 06:15 PM | #2 | ||
Last warning
i found i had to grind the brackets to make it fit back in.
it deffinately depends on the headunit. for a mates car i had to grind bits off to make it go back in. mine went back in, but took a lot of force. just try and modify the bracket to make it work.
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer |
15-06-2005, 06:24 PM | #3 | ||
okay.. wasnt sure if i had to.. but ok ;)
Cheers for that ;) |
15-06-2005, 11:53 PM | #4 | ||
Cruisin' When-ever I Can!
I have an alpine headunit and i had to cut a few chunks out of the bracket to get it to fit to the side of the headunit... Also had to drill holes in new places.
Didn't need any force to get it back in tho. Slid straight in snugly with no problems...
2006 BF XR8 - Lightning Strike - Herrod quad system with Herrod extractors, Coil overs, Whiteline swaybars, Powerbond 25% Underdrive. More mods to come! Ex 97 EL Futura, 04 XR6 and 07 XR8 Owner. |
16-06-2005, 12:58 AM | #5 | ||
Kaddis Customs
i've got an EF and the old head unit was taken out when i got it and i have no mounts at all! tried the wreckers they had no side rails off a stock head unit going back soon to check again....anything else i could get to mount a new pioneer in??
FG XR6 E-Gas Ute in Ego |
16-06-2005, 09:20 AM | #6 | ||
A V8 salute to my DEATH
I have an EF and i fitted a sony x-plod system into it. I was able to use the factory brackets and it slid straight in. Some may be slightly larger though.
1981 Toyota Hilux, 4inch lift, 33" Buckshot Mudders, LSD diffs, bullbar, driving lights, rollbar, toolbox and a 253 V8 |
16-06-2005, 09:30 AM | #7 | ||
B-Series Powered!
When I fit a head unit to my EA before it was stolen i had to weld the bracket from the headunit onto the brackets that came with the car..
2003 BA Futura Pacemaker 4490's, 2.5" metal cat, 2.5" mandrel bent exhaust, hi-flow air filter, more to come! |
